586,075 active members*
3,937 visitors online*
Results 1 to 17 of 17
    Mar 2010
    621
    Gast Vane pump... vacuum hold down
    Just curious if anyone has ever tried using one of these small vane pumps in a vacuum hold down type setup...
    These are "oil-less" design pumps which produce clean air and require no lubrication. Please see all the pics. Approx Performance Specs: 145 Watt, 0.12 - 0.15 horsepower, 10-15 psi pressure, 22-23"hg vacuum.
    2-23hg... would it work?
    Gast USA 24V Brushless Rotary Vane Air Pump/Compressor 24 volt DC *** Special! | eBay
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Aug 2011
    999
    Re: Gast Vane pump... vacuum hold down
    I use it all the time and really like it. and I know I know other folks use it as well. It is however only suited for smaller parts (let's say min 4 square inches, max 500 square inches) of solid wood or plywood and it must be well gasketed, no cracks in the wood and forget mdf since it is too porous.
    It is not possible to cut larger sheets on a spoilboard. for that you need a high volume blower with 5 or 10hp or more.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Mar 2010
    621
    Interesting...
    I'm gathering that the size of the piece to be held plays a major part in the amount of volume and HG needed.
    Assuming a 24"x24" area what type of continuous HG/volume do you think is needed?
    I also noticed this type of Vane pump that contains essentially air pressure and vacuum (Gast 1531-107B-G557X Rotary Vane Vacuum Pump and Compressor **BARELY USED!!" | eBay) any thoughts on its performance? Maybe killing 2 birds with one stone...
    Adam,
    Aug 2011
    999
    Quote Originally Posted by adam_m View Post
    Interesting...
    Adam,
    Sorry, I just looked up the pumps you mentioned...not sure about the vane version. I do have a GAST pump as well as a Thompson pump but these are of the dual rocker piston type (oil-less), also purchased refurbished on eBay for about $150.
    As for the size, the larger you go, the more leakage you will have to deal with. On the other hand, the larger surface will give you more holding force even if the vacuum drops. You will need a vacuum gage to see if the vacuum keeps dropping after turning it on and to make it practical you need a vacuum reservoir, maybe 2-3 gallons, to allow for the initial suck-down while the gaskets are not fully sealing.
    But otherwise, I use the vacuum pods maybe 80% of the time since it is so quick and easy without clamps, screws, fences, tabs etc. and saves material since you can go to the actual material boundary. Only reason to use other methods is if the parts are too small, have too many holes or the wood has cracks and knots.
    I have a full-size 36x48" extrusion t-slot table but converted (sealed) 6 of the slots to vacuum conduits with a taped-on cover of thin aluminum flashing. I can tap that anywhere by punching a small hole into the aluminum (can be sealed with tape again) and putting a disposable "pod" with gaskets below and above on that hole. Difficult to explain but I can post a picture if interested.
    Feb 2009
    6028
    We have all types of gast pumps at work. The vane ones are SUPER loud and run REALLY hot, but they do pull more volume per size than the piston or diaphragm types.
    Sent from my SM-T813 using Tapatalk
    What's the CFM rating on that little pump? I have a 3CFM Gast rotary vane pump, and it's noticeably better than a 1.5CFM pump I had. At least with wood, where the vacuum leaks through the material.
    Jan 2015
    138
    Until I can afford a vacuum pump I'm using my shop vac. It works fine for things 2' on a side. For 1' square I need to reduce the cutting speed/depth i.e. the force applied to the work.
    Plenty of cfm, not as much vacuum. I use rubber roofing material (EPDM) for gaskets since I have a lot of it and it is easy to cut.
    Steve
    Mar 2010
    621
    Jerry,
    Here are the stats on that vane pump, the larger of the 2.
    Pump Operating Type: Compressor & Vacuum Pump Combination
    Power Source: Electrical
    Lubrication Type: Oil Free
    Horsepower: 1/10 hp
    Motor Phase: 1
    Supply Voltage: 115 V
    Frequency: 50/60 Hz
    Maximum Continuous Pressure: 15 psi
    Maximum Vacuum: 335 Mbar
    Maximum Vacuum Mode Flow Rate: 1.25 (50 Hz) cfm, 1.5 (60 Hz) cfm
    Inlet Port Size: 1/8 in
    Outlet Port Size: 1/8 in
    Overall Length: 227.8 mm
    Overall Width: 106.4 mm
    I can't find any specs on the smaller unit, model #2032-V110-G635 except for the following:
    Gast 2032-V110-G635 24V Brushless Rotary Air Pump/Compressor 24 volt DC 6.1 AMP .12HP 3500RPM
    , its not on their website that I can see.
    Jerry, your using this particular pump the 24volt deal? How noisy is it?
    I'm guessing a shop vac might work for my situation but I would need to build a box since my table doesn't allow for access below, or at least it would be difficult to do.
    I'm thinking the "Hockey puck" scenario might be my best approach to get started and test with. What type of CFM and HG would those require and are they calculated by the piece?
    Adam,
    Jan 2008
    1529
    Quote Originally Posted by sajurcaju View Post
    Steve
    You may already do this, but a combination of vacuum and clamp holding works great. Clamps or blocks on the edges of the piece stop lateral movement and the vacuum stops lifting and sucks the piece flat.
    Jan 2015
    138
    Great suggestion pippin, I'll try it.
    Steve
    Mar 2010
    621
    We'll I bought one of the small pumps and I'll see what it has in store for small part holding..
    Adam,
    Jul 2007
    55
    I'm looking for something similar too. Could anyone tell me this is a vacuum pump or compressor?
    I wonder if it's for sucking air or blowing air. Thank you.
    Don
    Mar 2013
    319
    Two sides of the same coin, if it blows it must suck and vice versa... it is both a compressor and a vacuum pump.
    Jul 2007
    55
    Quote Originally Posted by zeeflyboy View Post
    Thanks, man. Simple and direct answer.
    May 2005
    3920
    Nope! But the first thing that come sot mind is why would you buy a 24 VDC pump. GAST makes many designs that can plug right into the wall outlet which are simple to use.
    When it come s to holding something it really comes down to how much leakage will you be expecting. You can get a hold down with a very little volume but it takes a long time to pump out the air. Once the air is pumped out you get the same holding power as with any other pump. The problem comes with leakage which little pumps can't deal with.
    Adam,
    If it was me the first thing I would do is to look for a 110 VAC pump preferably with a much higher volume capability. Running on regular line voltage solves the power problem and a larger pump will better deal with all the potential leakages you might have.
    In automation we use all sort of vacuum pumps from venturi types up to huge pumps used to pump down vacuum coating chambers. In the end it is the volume capability of the pump that generally makes the difference (excluding very high vacuum applications) as the volume capability impacts time to grip a part or empty a chamber. Remember you literally are pumping air out of whatever you are trying to pull a vacuum on. Once the air is pumped out you then need to worry about any leakage, if the leakage is so great the the pump can't keep the pressure low you will release your parts. This is where vacuum chucking can be a problem if you are cutting completely through the stock as you can have so much leakage the part send up sliding around. There are ways to deal with this so pump volume is only part of the solution and frankly can only handle a small amount of leakage.
    Honestly I wouldn't bother with the pump at all. If you want a nice GAST vane type pump get a much larger unit.
    May 2005
    3920
    Interesting...
    Volume is of interest in two ways. One the initial pump down time to empty a chamber of air and two the ability to overcome leakage into that chamber. The actual pump down pressure isn't as big of a deal as some make it out to be as most pumps can draw a pretty good vacuum. In the end all you have to work with is atmospheric air pressure, the vacuum pump dines't actually create pressure that is the air sitting on top of your part. In effect you pump the air out from under the part and the air on top creates the clamping pressure.
    Sadly there are many variables so the only honest answer is that it depends. In the machine tool industry guys are using little venturi vacuum generators to clamp parts to a milling machine sub table. If the box under your parts is real leaky you may need 1 or 2 horse powers worth of pumping capability. If cutting through the parts results in heavy leakage you might not have enough capability even then. This is why guys go to various extents to try to control leakage on their tables.
    Adam,
    Well I'm not sure I'd call them compressors. In any event you don't want restrictions on your pumps output.
    In the end you just can't say which pump will be right (it is mostly an issue of volume) until you understand you your table vacuum box will be constructed and how you will be machining part son the vacuum table. What you will need performance wise can vary widely. One usage might get by with a venturi generator and right next to that machine you might need a Roots blower.
    May 2005
    3920
    Adam;
    Based on the CFM spec I wouldn't bother with that pump unless you have a really tight vacuum box with little to no leakage.
    Jerry,
    I can't find any specs on the smaller unit, model #2032-V110-G635 except for the following: , its not on their website that I can see.
    Adam,
  1. Who sales rotary vane vacuum pumps, 750 to 300 CFM
    By litleboy in forum Want To Buy...Need help!
    Last Post: 12-15-2016, 01:59 PM
  2. Vacuum pump size for vacuum hold down jig?
    By dawgwalker in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-21-2014, 03:07 AM
  3. Help testing and repairing Thomas rotartry vane vacuum for my molder...
    By Robot Dude in forum Vacuum forming, Thermoforming etc
    Last Post: 05-09-2014, 04:43 PM
  4. Help with Thomas rotary vane vacuum test / repair.
    By Robot Dude in forum Work Fixtures / Hold-Down Solutions
    Last Post: 05-08-2014, 03:03 AM
  5. Vacuum hold-down: pump rating?
    By Henry DesignMfg in forum DIY CNC Router Table Machines
    Last Post: 03-18-2012, 12:58 PM
