586,076 active members*
3,708 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Russian Arduino Lead Screw Project??
Page 7 of 7 567
Results 121 to 128 of 128
  1. #121
    Jun 2019
    16
    Re: Russian Arduino Lead Screw Project??
    Hi thank you for your reply I may need to revert back to older version if I cant get information...many thanks though
  2. #122
    Jun 2017
    32
    If you have trouble getting what you need, let me know and I'll go onto chipmaker and ask.
  3. #123
    Jun 2019
    16
    Quote Originally Posted by bowcoastie View Post
    Hi that's very kind of you. First is there any difference between the standard prototype and Nicholai67's board. Second I am using a standard type rotary encoder square wave do I need to short out where indicated. Little confused on this note posted earlier ..see pic
  4. #124
    Nov 2006
    78
    Hiya Stroheim, Yep , solder the jumpers. Nicholai 67 is better than the Oil Major's, if that's what U mean, cos it is the same format as the Mega.(physical shape).
    The hand encoder is wired to the relevant plug/socket on the board, the Spindle encoder is wired to the input U referred to, the links soldered will transfer the quadrature signals to the Arduino Mega.
  5. #125
    Jun 2019
    16
    Quote Originally Posted by qtronpowerson View Post
    Hi thank you for replying. I have built the system but I have no LCD readout and several functions don't work. I have double checked all my wiring and seems ok. I suspect its because i am using the standard prototype board see pic and I should be using the Nicholai 67 board and I need to source one of them
  6. #126
    Nov 2006
    78
    Hiya Stroheim,
    technically it shouldn't matter which breakout board is used, but the Nicholai 67 breakout adapter makes it fairly fool-proof.
    And, U get the luxury job of crimping all those JST pins onto your loom wires! The appropriate too is required for that.
    Without seeing exactly what U have done its hard to advise..
    JLCPCB.COM in china can make the Nicholai 67 cheaply, but bear in mind those JST's. Of course U could simply sider the wires directly to the PCB
    just "reorder " from my attached file reference- should work.
    Cheers, stay safe.
  7. #127
    Jul 2003
    6
    Could someone be kind enough to post the Nicholai 67 breakout adapter gerbers please? I tried downloading them from the chipmaker.ru site, but had no luck.
    Thanks!
  8. #128
    Nov 2006
    78
    Hiya Jazz,
    After a bit of file searching i found em.
    cheers,
    Qtronpowerson.
    note: This forum wont upload RAR files!
    i got mine made by JLCPCB, China.
    I have a spare if U like
    Attached Files Attached Files
Page 7 of 7 567
  1. Electronic lead screw (gear box), with Arduino for lathes
    By the_muck in forum CNC Machine Related Electronics
    Last Post: 05-01-2023, 09:19 PM
  2. Lead Screw pitch and Bearings,coupling for lead screw
    By Power_user_EX in forum Linear and Rotary Motion
    Last Post: 06-12-2012, 12:37 PM
  3. Russian CNC project - my first router
    By maxvovk in forum CNC Wood Router Project Log
    Last Post: 10-21-2007, 11:59 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
