586,103 active members*
2,971 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC Oi-MB rigid tapping problem
    Feb 2017
    i'm having trouble rigid tapping on my VX500, G84 cycles thru but does not produce good thread, M29 will cycle thru but it will alrm out at the end when gets to G80. can somebody tell me what parameters setting should be from #5200 down? my control is Fanuc Oi-MB
    Feb 2006
    1792
    Re: FANUC Oi-MB rigid tapping problem
    Post your code.
    Are you sure rigid tapping is available on your machine?
  1. Rigid Tapping Problem
    By EricMFG in forum Kitamura
    Last Post: 09-15-2012, 03:07 AM
  2. Rigid tapping problem on VF-2
    By Frank_S in forum Haas Mills
    Last Post: 07-06-2012, 06:45 PM
  3. Rigid Tapping OM-D problem
    By yoshi900 in forum Fanuc
    Last Post: 03-04-2011, 03:21 PM
  4. Having a problem using rigid tapping on my SL10..
    By locash in forum Haas Lathes
    Last Post: 05-22-2008, 02:15 PM
  5. Rigid tapping problem
    By GITRDUN in forum Haas Mills
    Last Post: 11-16-2006, 02:27 PM
