586,094 active members*
3,942 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > How to match Timing pulleys and timing belt? (noob question)
    Feb 2017
    I'm a college senior in electrical engineering. I have (I assume) a pretty basic question regarding the selection of timing pulleys and belt. I'm wondering what I need to consider when selecting. Is it just the pitch and width of the belt and pulley that I need to consider? For instance, 11mm width and 5mm pitch; if all parts had these, would they be able to be used together? Or is there more that I need to know about each part? I'm new to all of this I am going to be using the parts in conjunction with a stepper motor.
    Thanks!!
    Sep 2007
    122
    Re: How to match Timing pulleys and timing belt? (noob question)
    Gates has some excellent "how-to's" on their site. I think there is even a calculator for center distance with each of the pulleys and belt. If you are using the same pitch pulleys and belts they will work. You can get two different size pulleys for a speed increase/decrease.
    You need to know your estimated torque and number of teeth on the belt and on each pulley. Then you can calculate your center distance.
    PowerGrip
    15362
    Quote Originally Posted by cdesantis01 View Post
    Thanks!!
    Yes you are on the right track, different Belt Pulley profiles for different uses, if you want high accuracy, then you would be looking at the Gates GT2-5 series Belts Pulleys , GT2 is the series the 5 is 5mm pitch, belt width your choice 9mm 15mm 25mm
    You will also see Gates GT3 also, which is the same profile, make sure you by American made as there are a lot of Chinese copies of the GT series which are poorly made, and don't match the correct profile
    Mactec54
  1. What timing belt and pulleys does Dave Nelson use?
    By i_r_machinist in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-02-2013, 03:58 PM
  2. Your process for determining the timing belt and pulleys
    By arvidj in forum Benchtop Machines
    Last Post: 01-06-2013, 03:17 AM
  3. Making my own timing belt pulleys - how?
    By damae in forum MetalWork Discussion
    Last Post: 08-01-2010, 04:51 PM
  4. Timing belt and pulleys
    By samakthachai in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-25-2007, 05:31 AM
