586,061 active members*
4,500 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Mold Center Of Gravity
    Jul 2006
    51
    does anybody have a spread sheet made up for calculating center of mold (that they would be willing to share)
    or at least point me in the right direction.(nuts)
    Nov 2006
    382
    Moldmaking center of gravity
    What type of mold? Injection, transfer, or compression. I have a couple of swags that work fairly well. I have found some products that work extreamly well. All I work on is injection molds (for 30 years). You can email me at [email protected] I will do what ever I can to help.
    Jul 2006
    51
    injection mold
    anything you can send me would be appreciated
    mcvitic@dixontool dot com
    Nov 2006
    382
    Mold center
    Progressive Components has a moving or sliding eye bolt. Or you can do like I do...calculate the weight of the plates, do slight bit of S.W.A.G. and you will be very close. Basicaly just calculate the over all rectangle. Subtract the volume of the ej housing (air) and pick the point. Solid works, AutoCad also have some of these calculations. The Progressive Components part is realy the best and simplest. They have a web site and a catalog that can be stuck right into AutoCad. Hey sorry this response was so late.
  1. gravity forming / free blowing cold rubber to make molds
    By drcrash in forum Vacuum forming, Thermoforming etc
    Last Post: 12-22-2006, 09:51 AM
  2. Gravity Diecasting
    By itsme in forum Casting Metals
    Last Post: 10-19-2006, 06:02 AM
  3. New Machining Center
    By porsche1220 in forum CNC Machining Centers
    Last Post: 04-28-2006, 12:34 AM
  4. what to do with center tap?
    By truman in forum CNC Machine Related Electronics
    Last Post: 01-21-2006, 05:21 AM
  5. Gravity fed system
    By noid in forum Mechanical Calculations/Engineering Design
    Last Post: 07-19-2005, 10:56 AM
