586,080 active members*
3,637 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Lathe threading inserts use and direction IR IL ER EL
    Feb 2007
    711
    Is there a difference between an external left hand threading insert, and an internal right hand insert?
    Same goes for external right and internal left.
    Can an ER insert fit an IR holder? Same question for EL insert in IL holder.
    Thanks.
    Feb 2013
    23
    Re: Lathe threading inserts use and direction IR IL ER EL
    Internal and external threads have different depths at the same pitch which might not matter much, but rake/clearance angles make a difference.
    Check the tool catalog or ask your dealer if a given insert might have all the same specs.
    Sent from my HTC One using Tapatalk
  1. Threading Inserts
    By boydage in forum CNC Tooling
    Last Post: 02-05-2015, 04:49 AM
  2. CNC lathe tools holder with carbide inserts
    By Sino-waterjet in forum News Announcements
    Last Post: 06-01-2012, 09:09 AM
  3. Regrind used carbide uncoated ISO lathe inserts
    By Euclid27 in forum CNC Tooling
    Last Post: 03-27-2012, 11:51 AM
  4. Selecting good lathe inserts
    By mikewohlford in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-18-2011, 01:58 AM
  5. Single Point Threading Inserts
    By John3 in forum Polls
    Last Post: 08-06-2007, 03:45 PM
