586,058 active members*
4,457 visitors online*
Thread: Totally Lost
Results 1 to 20 of 20
    Sep 2006
    22
    Unhappy Totally Lost
    Im very new to this so please bare with me.
    I recently went out and purchesed and pretty good laptop thinking that i will be able to just stick a usb to a r232 with a parrallel extention from the the lap top to the machine, what a huge mistake that was. when i first tried send a program i recieved an error stating that it could not find Com 3 so i installed some drivers and now i just use com 1, now when i hit send it says it is sending then it just seems like it locks up. The machine doesnt seem to be detecting that the laptop is connected to it. this may be just a problem within my setting but i really have no idea. so here i am, spent all this money on a laptop and very frustrated. I am using Mastercam X, Machine is a Takisawa Turning Center with Fanuc MCU. I have been going to school for programming and believe im ready to start some simple programs and my work. this damn connection this is hold me back from my raise damnit., lol. any help is apreciated. thanks
    24221
    First you have to make sure that data is comming out of the USB/com port, this is where a break-out box is a must for working with RS232.
    Also make sure the PC side is set to software H.S. & Hardware Handshake off.
    On this set up I would tend to use a three wire cable and jumper out the H.W. Hansdhake both ends.
    On 9pin jumper 1-4-6 & 7-8 on 25p 6-8-20 & 4-5
    Use connection only from 9p to 25p 2 -2, 3-3, 5-7.
    Al.
    Albert E.
    Sep 2006
    22
    yea i guess i really do need to make sure the data is comming out but i really dont have a way to do it. The end of the RS232 has a little LED light. but i have never seen it light up. so maybe nothing is going thru it.
    Oct 2006
    586
    Al.
    all is right fanuc has to wired the way he staited and the make sure in your settings and make sure your i/o channal is at 0
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Sep 2006
    22
    Al
    do you mean by those number that i have to have a cable wired specifically? didnt really understand. tonight i tried all the configurations as i used with Gibbs cam. now it seems that the information is sending thru the rs232 because the LED light up when i hit send, but the CNC machine doesnt recognize that the cable is plugged in. when i set the MCU to recieve i get an error say: DR SIGNAL OFF. Normally when the machine is ready to recieve it says LSK. so you think it may be the settings arent right or do i need a different cable. i kinda have a feeling it is the parallel extention but not sure.
    Nov 2005
    1468
    Yes, the cable HAS to be wired specificaly as said. You can get RS232 boxes for a couple of dollars from radio spares or radio shack that let you plug in little pins to make the correct connections.. it sort of goes in between two cables.. like splitting the ribbon cable and crossing over some wires.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Sep 2006
    22
    would some kind of pcm card work aswell? or would that require some custom wiring also? i am also using the same parallel adapter as i was before on a different laptop with gibbs and that worked. so i dont understand why it doesnt now.
    Jul 2005
    USB to Serial adapter for DNC is somewhat of a crapshoot - some adapters may work others won't, I bought 3 none worked. After about two weeks of checking cabling, messing with FIFO buffer settings and other such nonsense I finally gave up and when with a tower w/ real serial port on a shop cart - worked like a champ first time. PCMCA card may work but they are quite expensive $100.00+ last time I checked - again no guarantees this will work either.
    Feb 2007
    664
    use a strait through cable with a jumper box at the end http://www.sfcable.com/store/31d3-f1.html
    connect the correct pin numbers on one side of the box to the correct pin number on the other
    Sep 2006
    22
    USB to DB9 and DB25 Adapter
    http://www.sfcable.com/catalog/whole...s/UB30-50.html
    This is pretty much what i am trying to use right now. is there a way to use that jumper box with those cables or am i going to need a usb to a db25 then the jumper.
    i also found this site (http://members.aol.com/easyio/schematics.html) to try and figure out the wiring but not sure which one i need for those cables
    Feb 2007
    664
    Quote Originally Posted by FAMOUSX1 View Post
    it should work ,the 9 to 25 looks like a straight through adaptor
    Sep 2006
    22
    how does the jumper work. do i solder the wires al the way across or do i use the little holes in the center. also could i just get a female db9 and a male db25 and just wire as directed. kinda make my own with some thing like this.
    http://www.l-com.com/item.aspx?id=3096 .
    Feb 2007
    664
    that would work better, good idea
    Sep 2006
    22
    went to the shop last night to try out all that wiring and nothing worked. machine still does not detect the cable. i have the diagram of the machines serial port but im no sure how to read it.
    Feb 2007
    664
    if i remember correctly you had some doubts about your lap top working for this task
    if you have a pc with a real comm port try that first
    that way if it works you wont have to play with the machines port
    Oct 2006
    586
    Try this 9 pin (pc) 2,3,and 7 machine side (25 pin) cross 2-3, 3-2, 7-7 .....then jump these 6-8,8-20(may have to jump 4-5 together) this is how my machines are wired and i use 4-5 some you dont
    Apr 2003
    3578
    What shop in Valencia as I can help you.
    Cadcam
    May 2007
    23
    Posted in wrong spot sorry
    Jan 2007
    333
    I have used a MAC and Windows both with USB to Serial adaptor (with drivers),
    then through a Null Modem adaptor:
    http://www.dalco.com/ProductDetails2.aspx?sku=59095
    then to a 9pin to 25pin adaptor:
    http://www.dalco.com/ProductsList2.a...54&selection=2
    to the CNC control and both worked flawlessly as long as I matched settings with the CNC (baud, data, parity, stop bits).
    Several types of FANUCS, Milltronics, Hitachi-Seiki, etc.
    Nov 2006
    89
    Loopback connect (hillbilly style)
    Get an old cable. Leave a couple of inches and cut off a connector that will fit on to your USB adapter. Strip a little of the end of each individual wire. Use a meter to identify each pin number andtwist them together as is shown.
    Use Hyperterm in Windows in half duplex mode. When you type a letter once it will show on the screen twice. (Once local Echo and the second is "remote echo")
    Once you get double characters you know the USB is talking correctly and then you can go on to whether the next device is listening.
  1. Please tell me if I´m totally off PSU
    By gotis in forum CNC Machine Related Electronics
    Last Post: 08-10-2006, 03:59 AM
  2. Totally New to Machining Where to start
    By Warlock in forum MetalWork Discussion
    Last Post: 08-05-2006, 11:50 PM
  3. Totally Fed UP!!!
    By rhino in forum Servo Motors / Drives
    Last Post: 06-02-2006, 08:06 AM
  4. Totally new at CNC
    By mochi30 in forum DIY CNC Router Table Machines
    Last Post: 06-11-2005, 04:29 PM
  5. Man, I'm lost
    By mrcodewiz in forum Benchtop Machines
    Last Post: 06-14-2004, 09:51 PM
