586,110 active members*
3,257 visitors online*
IndustryArena Forum > MetalWorking Machines > Smithy > Stupid Simple Bar Puller - on the FL300 lathe
Results 1 to 14 of 14
    Aug 2007
    701
    I haven't seen this idea posted before so I thought I would share.
    This is a simple bar puller - an empty ER25 collet. Works perfectly and is easy to dial in the right tension.
    I do make a 0.025 chamfer on the end of the rod after a part off to make it easier for the stock to slide into the collet.
    Lovin' the FL300 lathe. Easy code to open (M11) and close (M10) the chuck.
    Feb 2017
    Re: Stupid Simple Bar Puller - on the FL300 lathe
    Nice job brianbonedoc. I am sure you have already figured it out, but if you add line numbers....like N1 as the first line, on the last line, you can add a GOTOB N1 statement and loop through your program for multiple parts.
    Have a good day!
    Aug 2007
    701
    yes I have that code in there - and an M1 just in case! . Thanks!!
    Apr 2005
    149
    Neat Brian !
    You're just using collet tension provided by the nut to do that?? Slick!!
    Dan
    Aug 2007
    701
    Dan yes that way it's easy to dial in the tension. I did shove a 1/2 in aluminum rod down the back of the tool holder to keep forward pressure on the collet. Without it the collet would get pushed back as the stock was pushed into the collet.
    Sent from my iPad using Tapatalk
    Apr 2005
    149
    I don't think I would have ever thought of doing that!! Just neat!
    I see you have coolant at the turrett like I do. Do you by chance know the thread of those brass ports?? I need to get those aimed the right direction with some fittings & tubing. I WISH we could just buy the parts!!
    NEAT NEAT NEAT Bar puller! Dan
    Aug 2007
    701
    Dan I was just looking at that too! I think it's either 1/8npt or m4??
    Apr 2005
    149
    Brian, as far as I can tell it's metric... and I think M4 is close. Nothing in my shop will scrw into it so I am sure it's metric. I'll get to the bottom of it tomorrow and will let you know. I just thought you might have already known. I'll drop Kade a note and see if we can just buy the parts.
    Thanks Brian. Dan.
    Aug 2007
    701
    I was almost thinking the tormach ones may fit - or I will just buy some copper tubing and thread it on the lathe
    I'm out of town so I can't test it now
    Aug 2007
    701
    I just put in an M5x.8 and it threads in perfectly. That seems to be the same size that tormach sells. If i can find some 5mm copper tube I'll just make my own
    Apr 2005
    149
    Quote Originally Posted by brianbonedoc View Post
    Thanks Brian! I hadn't had time to look into it any further. I did drop Kade a note but haven't had a reply. He may be traveling again. THANKS!!! Dan.
    Aug 2007
    701
    Dan - so check this out: I bought 3/16 copper brake line from amazon 25ft/$25
    25 Ft. Roll / Coil of 3/16" Copper Nickel Brake Line Tubing https://www.amazon.com/dp/B015YGQYW2..._pcE6GQVDgNOfE
    Then cutoff about 10" and threaded 3/8" of the end to M5x.8
    It threads right in to the coolant port!
    Aug 2007
    701
    Here's a video of it in action:
    Apr 2005
    149
    Very Neat!!! Thanks Brian! I'll do the same. Dan
  1. CNC Lathe Bar Puller
    By BCARL in forum For Sale Only
    Last Post: 02-07-2015, 03:01 AM
  2. CNC Lathe Bar Puller
    Last Post: 02-06-2015, 06:09 PM
  3. Stupid simple wireless pendant
    By darrellatg in forum Videos
    Last Post: 06-02-2011, 05:41 PM
  4. Stupid simple but??
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-27-2008, 03:55 PM
  5. CNC lathe plus Bar Puller help
    By SeaSchell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2006, 12:44 AM
