good day to all,
Need help with hypertherm THC. The machine i am working with seen to have a problem on the THC, the problem i was facing now is after the arc is transfer and start to move the torch lifter will start to move up until the arc cut off. Any advice on what i can check or do. Controller is using edge II with sensor THC PCB
hope to get a replay asap from cnczone friends =)
