Hi All,
I having issue with my 80 watt Laser X axis. The belt need to be change so I changed it. But issue still same. As I cut 25mm x 25 mm. it cut perfect with tolerance of + - 0.05mm. But when I cut 900mm x 25mm the it cut 907mm instead cutting 900mm. Y axis is perfect. X axis giving issues. Any one can help?
