586,576 active members*
3,415 visitors online*
Results 1 to 10 of 10
    Aug 2010
    45
    wiring without Breakout Board
    I have a router that went out on me a 6 months back. I wired it 12 years ago and when I have gotten around to working on it again I decided to use a breakout board instead of direct wiring to the 25 pin connector. I got a cheap chinese breakout board and found it doesnt work. I hastily cut the wires off the 25 pin connector and now I cant remember how to wire the homes and limits. I have 3 three wire proximity switches, one for each axis used as home and limit. I have them wired to a 24 volt supply normally closed. When tripped it operates a relay that sends the signal to the proper pins. I am using mach3, I cant remember if I am sending a 5 volt signal to the pin. Can someone help me with a 1st grade mentality explanation of what I need to do. Even a diagram of the whole setup would be great.
    Tony P
    Mar 2007
    2083
    Re: wiring without Breakout Board
    what type of N/C proximity switches do you have open collector NPN or open collector PNP ??
    a web search for the part number should find the data sheet
    if they have NPN outputs then you can connect all the positive supply terminals to +24V
    the negative supply to the first switch and its output to the sucond switches negative supply terminal
    then the output of the second switch to the negative supply terminal on the third switch
    the relay coil between the positive supply and the third switches output
    add a diode across the coil with its cathode to the positive supply
    connect the relay common to the printer port ground and the normally open contact to the printer port input you decide to use
    if you have used pi 10 as your E-stop to your PC you can use any of these four pins -- 11 , 12 , 13 or 15
    John
    Aug 2010
    45
    I have the relay working when the limit is tripped. I just dont know what signal to send to the pins 11,12,13 or 15, Is one of these 5v and where does it go. the prox switches dont have a part number but are three wire blue brown and black.
    Mar 2007
    2083
    you just need to connect the relay contacts between the printer port ground and the input you have chosen
Name:	proximity switches & relay.jpg
    john
    Aug 2010
    45
    IS THE INPUT TO PINS 10,11, 12, 13 AND 15 0 VOLT OR 5 VOLT.
    Mar 2007
    2083
    the printer port inputs have a weak pull up to +5v on old PC printer ports ( on new PC's the input has a weak pull up to 3.3V)
    when short circuited to ground a current of about 1.6 mA (0.0016A) will flow and Mach 3 (or4) will see a logic 0
    when open circuit the input will be just under 5V and Mach 3 will see a logic 1
    the ground pins 18 to 25 is 0V and on a desktop PC is connected to the mains supply earth via the power supply
    John
    Aug 2010
    45
    remember i am a 1st grader. does that mean that i am putting 5volt into the 11,12,13,15 pins from the relay that the switch tripped?
    Mar 2007
    2083
    just think of your relay contacts being like a simple on / off switch connected between the printer ports input pin and a ground pin
    John
    Aug 2010
    45
    That I get. I told you first grade language. Sorry for being such a pain in the but and thank you
    tony
    Mar 2007
    2083
    Hi Tony
    glad we got there in the end
    sometimes I can forget not all members are on the same page when it comes to electronics
    John
  1. wiring breakout board 6 axis
    By djebbar in forum Machinery Manuals / Brochures
    Last Post: 03-21-2015, 08:52 AM
  2. CNC4PC.com C11 Breakout Board wiring.
    By thunderdork in forum CNC Machine Related Electronics
    Last Post: 10-29-2013, 06:53 PM
  3. Breakout board wiring help!
    By frostyshoal in forum DIY CNC Router Table Machines
    Last Post: 05-08-2013, 03:05 AM
  4. wiring Chinese Breakout board
    By silyavski in forum CNC Machine Related Electronics
    Last Post: 07-29-2011, 02:22 PM
