586,655 active members*
4,599 visitors online*
    Feb 2017
    Rhinocam 2016 to mach3 mm loosing steps V carving embossing
    Hi everybody, I'm writing with the hope somebody would have encountered the same problem then me...
    I'm using rhinocam with mach3.
    My machine i correctly setup, motor tuning and acceleration is fine.
    If I try to run a simple square in 2D with defined dimension it works perfectly.
    Problem starts when I'm doing V-carving with a 45° V bit.
    Even thought the G-code seems to be correct and the preview in the cam software is exact the cut is different.
    I seems that I'm loosing steps at the end of my code ruining my piece of work
    In the attached images you can better see what's my problem.
    We can clearly see what's happening at the upper right corner that stays rounded. The V bit exit to early...
    G-Code:
    Lines comming from the exterieur square supposed to be cut by the v-mill
    G00 G49 G40.1 G17 G80 G50 G90
    G21
    (V-Carving)
    M6 T1
    M03 S20000
    G00 Z10.0000
    X284.9980 Y15.0020
    G01 Z-5.0000 F103.0
    Y184.9980 F300.0
    X289.9980 Y189.9980 Z0.0000
    X284.9980 Y184.9980 Z-5.0000
    X15.0020
    X10.0020 Y189.9980 Z0.0000
    X15.0020 Y184.9980 Z-5.0000
    Y15.0020
    X10.0020 Y10.0020 Z0.0000
    X15.0020 Y15.0020 Z-5.0000
    X284.9980
    X289.9980 Y10.0020 Z0.0000
    X284.9980 Y15.0020 Z-5.0000
    G00 Z10.0000
    M5 M9
    M30
    Lines at the same moment from the entire code
    G00
    X284.9980 Y15.0020
    G01 Z-5.0000 F103.0
    Y184.9980 F300.0
    X15.0020
    Y15.0020
    X284.9980
    Hopefully somebody had the same problem previously and could help me to figure out.
    Best regards
    Lucas
    Re: Rhinocam 2016 to mach3 mm loosing steps V carving embossing
    Acceleration that works fine for 2D work may be too high for 3D and V Carving.
    Reduce your acceleration by 50%, and see if it fixes the issue.
    Feb 2017
    Thanks a lot for replying i'm gonna try that now
    Feb 2017
    THX great advice, I tried few times by decreasing the acceleration and it worked perfectly, I had to go down from 400 to 50.
    Apr 2018
    Hello everyone, sorry for my English.
    I'm new to the forum and I'm looking for a solution to a similar problem with rhinocam and mach3.
    I have problems with the rhinocam postprocessor to mach3 and I can not use the machine.
    I am testing a rhino trial version so I can not consult MecSoft.
    Lucas, have you been able to solve your problem?
    I would appreciate your help, thank you very much.
    Best regards.
  1. Loosing steps?!? Tried everything!
    By beentheunseen in forum Stepper Motors / Drives
    Last Post: 01-01-2013, 12:33 AM
  2. loosing steps in z axis
    By macatoms in forum Benchtop Machines
    Last Post: 05-05-2012, 08:16 AM
  3. BP Series 2,under Mach3...really loosing steps ?
    By Jerry7 in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2010, 10:27 PM
  4. RhinoCAM V-Carving
    By mc-motorsports in forum Rhino 3D
    Last Post: 02-02-2009, 09:58 AM
  5. Loosing steps
    By Normann in forum Automation Technology Products
    Last Post: 10-15-2007, 08:15 AM
