How have you guys that use proximity switches with the mx3660 wire them up? Do you need a separate power supply or can they be run off of the mx3660 somehow? The wiring diagram in the mx3660 manual doesn't show a connected power supply. Also for anyone that has an xzero machine, how have you installed the proximity switches on the long axis? There are slots machined in the z and the short axis for switches, but I don't see an obvious place for a limit/homing switch on either of the end pieces. Any help would be greatly appreciated, thanks!
