586,067 active members*
4,904 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Fagor 8055 Error "#36 No START. MOTOR HEAT SWITCH TRIGGERED"
    Jul 2009
    Angry Fagor 8055 Error "#36 No START. MOTOR HEAT SWITCH TRIGGERED"
    I am guessing this is a machine builder ( Lagun) error code.
    I looked for resets in the control cabinet. Reset the breakers.
    Looking for ideas of where to go next.
    Mar 2008
    169
    Re: Fagor 8055 Error "#36 No START. MOTOR HEAT SWITCH TRIGGERED"
    PLC error : Maybe you have an overheated motor or a broken wire.
    Carlos Cabrera
    May 2015
    Quote Originally Posted by wazie View Post
    Hi I'm not sure if it helps but I had a problem on my chic poncho lathe.8055. Turned out there was excessive ohms on the drive motor caused by a problem thermister in windings. The problem was sorted by placing a resister on affected pin out to drives to fool system alarm disappeared but now have no motor overtemp alarm. It's a price to pay for a working machine
  1. Replies: 7
    Last Post: 10-03-2018, 07:46 PM
  2. Replies: 5
    Last Post: 05-24-2017, 10:37 PM
  3. "limit switch triggered" aleatorio en Mach3, Ruido?
    By lamartinada in forum Spanish
    Last Post: 11-20-2013, 07:28 PM
  4. Replies: 3
    Last Post: 09-30-2013, 08:55 AM
  5. Fagor error code " No Spindle Speed Value "
    By Hirro in forum Fagor Automation
    Last Post: 06-20-2013, 02:32 PM
