586,389 active members*
3,228 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Newbie to MADCam - Need help, Please
Results 1 to 5 of 5
    Hi guys
    Please help. I have watched the videos on YouTube, running Win10,Rhino5, Pre-release MADCam. I have changed over from RhinoCAM and am having a huge problem with understanding the workflow to doing a "simple" Flip and then Rotary for milling Wax items (Rings mainly) on a 4 axis machine, MiniTech MiniMill 3. Is there anywhere that I can find "instructions/examples/videos/strategies ?
    What I can't seem to get through me thick skull is:
    1) Rotate 180 deg for flip and then return to 0
    2)On Rotary, to mill only certain sections and then other areas, or alternatively to rotate to a certain degree, mill a section using 3 axis commands, and so on. Is there a jewelery module for this "Dumb" Mill challenged person?
    May 2013
    261
    Re: Newbie to MADCam - Need help, Please
    There are quite a few ways to approach this ..... but this is the easiest to start with
    use the five axis option buttons ( you do not need a five axis machine to use the drive surface options as long as the drive surface is flat and or curved in the fourth axis ) think about a sleeve around your ring anything in the shadow of that sleeve will be cut to the chosen depth.
    This drive surface can be anywhere in the 360 degrees around the part and it can be shaped to cut only what you want ..... like inside a hole
    or inside the bezel on a ring
    There are plenty of videos on how to create a tool path with drive surfaces
    Quote Originally Posted by Gregore View Post
    use the five axis option buttons ( you do not need a five axis machine ... drive surfaces
    Thanks for the reply Gregore, I only have the 4 Axis + version so when I try any 5 axis "Tools" they don't work
    May 2013
    261
    well that certainly makes it harder to understand efficient work flows ...... but using boundary curves to control where the cutting takes place and its borders , one can also use a surface plane to control how deep the cutter can go .
    i am including a link to a standard 4 axis cut strategy and you can also look up NSCNC they used madcam for quite some time then shifted to their own system , so some of the early video use madcam layout and strategies .
    https://www.youtube.com/watch?v=wOYNC_abRTw
    hope some of this will be helpful
    Thank you, will give that a go
  1. I need madcam 4.3
    By AdamD in forum MadCAM
    Last Post: 05-14-2014, 08:57 PM
  2. USE MADCAM WITH MY EDM???
    By Steve.B in forum Waterjet General Topics
    Last Post: 01-22-2010, 07:08 PM
  3. Tell me more about MadCAM...
    By phil m in forum MadCAM
    Last Post: 01-13-2010, 07:33 PM
  4. How do you use Madcam?
    By turmite in forum MadCAM
    Last Post: 07-28-2007, 07:12 PM
  5. New US rep for Madcam
    By turmite in forum News Announcements
    Last Post: 07-08-2007, 01:14 AM
