586,094 active members*
4,055 visitors online*
Results 1 to 3 of 3
    Oct 2016
    no axis movement
    I have not gotten much assistance from the hobbycnc website, and am only making things worse trying to fix this on my own. I purchased a 3 axis pro board, and after completing the initial assembly, I had 4.93v at the test point. I completed the rest of the assembly, set the current on all three axis to .42v, and installed the board. Initially, I had very slow movement on the y axis, and none on the other ones. After a few minutes, the motor shut down as if it were going into protect mode. If I turn the board off for a few minutes and turn it back on, it goes for about 5 secs, then shuts down power to the motors again. I removed the board, verified I still had 5v, and checked the current on the axis again. I had .42 to x and y, but now have no voltage at all on the z pad. I am using a 12v pwr supply for testing and have 11.79v on the U6 regulator, and 4.93 on U5 and U7. I also have continuity on all three posts of the z axis pot. I have also verified everything is oriented correctly, and all solder joints appear solid with no bridges. I also now only have 0.006v on the y axis. I do still have .42v on the x axis. Thanks for any help, Scott.
    Oct 2016
    Re: no axis movement
    It appears the two pins that send signal to the pots for my y and z axis are shorted together. It is not that way on my x axis that still works. What would cause this to short together. Surely I haven't fried the driver chips that easily.
    Apr 2013
    1899
    Quote Originally Posted by scottmcgraw View Post
    That's impossible to answer unless we can actually repair your machine. Many things can cause a short circuit and without actually following the signals it is not possible to say why.
  1. 3 Axis CNC Mill Software for PC - Checking Axis Movement
    By rickwoz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-05-2015, 04:06 AM
  2. uncommanded A axis movement when doing 4 axis work.
    By Tristar500 in forum Mach Mill
    Last Post: 09-12-2014, 02:47 AM
  3. X axis differential to create Y axis movement.
    By mpatterson557 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2014, 12:18 AM
  4. Grinding and unexpected axis movement if rapiding 2 axis
    By DarkSabre in forum Taig Mills / Lathes
    Last Post: 03-26-2010, 05:37 AM
  5. 4th axis movement (and a few other gen ?s)
    By corpse in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2004, 12:13 AM
