586,106 active members*
3,009 visitors online*
    Jun 2014
    1780
    Vertical lines
    I have a problem that I havent had before with vertical lines or anomalies in the finished part. I have made a few hundred of similar parts and never noticed these lines.
    When i made the fixture I rotated the parts as I usually do for multiple parts, 29 degrees worked well for the part count, tool clearance etc, but I am wondering if this angle doesnt work well with the Tormach or Sprut 7 as its an odd angle?
    Have any of you guys had a problem such as this? I have adjusted the XY ways and they are in spec. I also use PathPilot v 1.9.8
    Kind of a head scratcher for me thats for sure............
    Any input on what may be a possible cause very much appreciated.
    mike sr
    Jun 2014
    1780
    Re: Vertical lines
    Update on this problem, the anomolies are created in Rhino 4, it has to do with the loft.
    I will have to figure a way to do the lofts differently, parts are servicable but cosmetically they leave a bit to be desired..........
    mike sr
  1. RDWORKS banding(vertical lines?
    By tigox in forum Laser Control Software
    Last Post: 10-28-2016, 02:48 PM
  2. Replies: 9
    Last Post: 01-11-2014, 11:04 PM
  3. Replies: 2
    Last Post: 08-26-2013, 07:37 AM
  4. vertical lines on display screen (Fanuc 18M)
    By sansgp in forum Mori Seiki Mills
    Last Post: 01-19-2013, 12:18 PM
  5. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
