586,840 active members*
2,206 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Torque confusion of a hybrid stepper motor
    Mar 2014
    1131
    A local seller sells this hybrid stepper and a drive for it. In the PDF I see holding torque is 86kg-cm which makes 8.45nm but no info about running torque. I asked the seller about this and he said that the running torque is double (16nm). This is the opposite I know about steppers.
    What do you think?
    http://sahinrulman.com/site/images/s...86H450C-60.pdf
    Sent from Shadowmoon Valley
    Dec 2013
    5714
    Re: Torque confusion of a hybrid stepper motor
    I think the seller is not correct.
    Mar 2015
    410
    The running torque can not exceed the holding torque because it uses the same stepper coils. However, the second coil does not to be used for micro stepping, it can be used to assist the first coil in keeping its position like running in full step. This means no loss in torque when doing micro stepping. The current flow is just enough to keep the position. This could result in lower heat up. But if the stepper needs all its power to keep/reach the position, it will heat up as much as a normal stepper.
  1. SONCEBOZ - Hybrid Stepper Motor
    By uros2002 in forum Stepper Motors / Drives
    Last Post: 10-06-2016, 06:39 AM
  2. Replies: 0
    Last Post: 04-27-2016, 10:05 AM
  3. NEW NEMA23 Hybrid Stepper Motor 570 oz-in in stock
    By automationtechinc in forum Automation Technology Products
    Last Post: 03-17-2015, 09:40 PM
  4. NEMA23 or NEMA34 closed loop stepper Motor System-Hybrid Servo kit
    By automationtechinc in forum News Announcements
    Last Post: 11-22-2012, 01:58 AM
  5. Drive for 3-phase hybrid stepper motor
    By Newbie2CNC in forum CNC Machine Related Electronics
    Last Post: 08-13-2009, 12:20 PM
