586,070 active members*
3,543 visitors online*
    CNC FREEFORM BENDER
    I have built a CNC freeform bender , Search Nissin freeform youtube to see one in action. I use CNC mills to cut molds now. We are trying to understand what we need to do to program this custom bender we built. It is 3 axis 2 for bend position and one axis for tube feed. We want to bend 3/16 copper tube for induction coils. can somebody steer me to cam software? or what I need to create my gcodes based on this configuration.
    Dec 2013
    5717
    Re: CNC FREEFORM BENDER
    That is the coolest tube bender I have ever seen.
    Thinking about the software to run that makes my head hurt. If I were doing this, I would write a program that would read the positions of the axes and then output the G-code. I would manually ''train'' the machine by jogging the axes then click the mouse at the transition points, much like is done with industrial robots.
    What kind of a motion controller are you using to run the machine?
  1. Looking For Bmp Bender
    By Acebull in forum Uncategorised CAM Discussion
    Last Post: 10-15-2013, 02:56 PM
  2. Scroll Bender
    By metalartist in forum Want To Buy...Need help!
    Last Post: 03-11-2011, 07:50 PM
  3. Diacro#3 bender help
    By mtlhe in forum MetalWork Discussion
    Last Post: 02-16-2011, 04:00 AM
  4. Steel bender
    By Redvan in forum Want To Buy...Need help!
    Last Post: 01-17-2011, 11:19 PM
  5. Smartcam Freeform Machining
    By edsgarage in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-28-2010, 01:45 PM
