586,320 active members*
3,716 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Feb 2007
    156
    Takisawa TC-1 Fanuc 0-TC
    Hello all!
    New to these forums, great info I've seen posted. I do have a question however. I have recently purchased a Takisawa TC-1 with a Fanuc 0-TC control. I am waiting patiently for an Operators manual from ebay and a programming manual from Fanuc America. What other manuals are suggested? Is there actually a parameter manual? One thing I did find out when programming a M68 (collet close) it waits for something, the command does not cancel. M69 however, works fine. Opens the collet and cancels itself. I've tried it in MDI, within a program to no avail. The parameter page looks greek to me, not what I'm used to plus I have no explaination on what numbers mean what. Also looks to be Binary?
    Thanks in advance,
    Dave
    (Schneider Machine)
    (A force of one)
    24221
    Some M codes require confirmation, could be a pressure switch depending on the method the collet is closed.
    There is a Description manual
    Connection manual
    Programming manual
    Operators Manual
    Maintenance Manual
    Parameter Manual.
    Operation & Maintenance Manual.
    Then there is the MTB Manual for the Machine control and M codes etc.
    Al.
    Albert E.
    Feb 2007
    156
    Thank you Al,
    I can change the clamp via the key switch to internal or external. That in turn reverses the commands. M68 now opens the collet and cancels itself. M69 on the other hand will not cancel. So, what ever it's waiting for is unknown as the problem changes
    What manuals in the list do you recommend, what will I get the most bang for the buck out of? Besides the operators manual and programming manual because they are already on the way.
    Thanks again,
    Dave
    Schneider Machine
    A force of one
    Feb 2007
    156
    OK!!!!! Found the pressure switch. I Adjusted it lower and the m68 code will cancel, I feel kinda stupid. This is my first hydrolic machine, used to pneumatic ones. Soon I will learn the idiosyncrasy's of this dang thing, after all, it's what keeps it interesting.
    Dave
    Schneider Machine
    A force of one
    Oct 2006
    586
    Chuck pressure will also cause your clamp un clanp to move slower primairly your clamp, not much slower but you can tell,
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    24221
    Quote Originally Posted by Dave1 View Post
    Dave
    Send me a PM with an email address, some exceed the server capacity though.
    Al.
    Albert E.
    Feb 2007
    156
    Al.
    Done,
    Thanks Al,
    Dave
    Schneider Machine
    A force of one
    Feb 2007
    156
    The programming manual from Fanuc America showed up on friday, sheese, does a person need a PHD and a Doctorate degree to understand the dang thing
    Today the manual from ebay showed up, sweet, wish I'd got that first:banana:
    Now it's time to do some tool block making, some reading, some programming, and some testing, but from what I gather the machine setting and tool settings are not what I'm used to. Seems confusing. Oh, it's not a G54 machine, it's a G50?????
    Dave
    Schneider Machine
    A force of one
    24221
    See if you have parameter 910 bit #1 set (xxxxxx1x)
    This should be G54~59
    Al.
    Albert E.
    Feb 2007
    156
    Al, that parameter is set to 0, I did try and change it to 1 and got 2 alarms, 401 and 430? I set it back.
    Dave
    Schneider Machine
    A force of one
    Oct 2008
    5
    Dear All,
    I have takisawa tc-1 with fanuc o-tc controler.
    my problem was few day ago the Dignotics parameters are lots.
    so please can help me,
    anybody have same machine. please sand me a this parameters.
    thanks in advance
    nilesh patel
    Feb 2007
    156
    Nilesh,
    You have a private message
    Dave
    Schneider Machine
    A force of one
    Dec 2004
    167
    the part number for the Fanuc OT parameter manual is B-62550En/01 .....it just happen to be sitting on my desk
    matt
    Apr 2009
    5
    Re: Takisawa TC-1 Fanuc 0-TC
    Best regards to everyone,
    I bought Takisawa TC-1.
    I would ask you if someone has operator manual, wirring manual...
    My e-mail adress [email protected];
    Tom
    Dec 2013
    267
    I also picked up a Takisawa TC-1 last week. My first CNC lathe, so any docs you guys have gathered up for this machine would help me greatly! Please shoot me a private message if you wouldn't mind sharing any soft copies you have.
    Any specific advise would also be helpful. My machine is a 10HP, 8 tool turret, hydraulic 3 jaw chuck came on the machine (I might look into picking up a collet chuck also if you guys have any advice on which to get).
    May 2010
    hi all,
    anyone here have takisawa TC1 CNC Lathe Fanuc OT parameter. My machine parameter lost recently and appear a lot alarm.
    通过我的 SM-G750F 上的 Tapatalk发言
    Apr 2009
    5
    Dear Mr. Darren75 ,
    Yes I have takisawa TC-1.
    What year is your machine?
    I have saved the machine parameters
    [email protected]
    May 2010
    Quote Originally Posted by cnc wedm View Post
    Dear Mr. Darren75 ,
    [email protected]
    my machine was year 1993. can sent to me by email
    [email protected]
    thanks a lot
    Apr 2009
    5
    Dear Mr. Darren,
    I sent you email from gmail account.
    cnc wedm
    Sep 2021
    6
    Good evening all, first time on here.
    I have a 1993 TC-1 had its parameters deleted. I have all the parameters except for the PMC parameters 900-939. If anyone has a copy it would be much appreciated.
    Regards
    Brad.
Page 1 of 2 12
  1. Takisawa TC-1 FANUC 0TC
    By alexfanuc in forum Fanuc
    Last Post: 04-07-2015, 08:32 AM
  2. takisawa with fanuc 21-T control
    By WonderY in forum Fanuc
    Last Post: 03-15-2011, 02:27 PM
  3. Takisawa TC-1 with Fanuc OT
    By Nilesh Patel in forum Fanuc
    Last Post: 10-23-2008, 07:13 AM
  4. Takisawa/Fanuc 3T
    By hammerdown in forum Fanuc
    Last Post: 10-17-2008, 03:06 PM
  5. Takisawa fanuc 5t m code
    By tim-tbl in forum G-Code Programing
    Last Post: 06-20-2006, 02:41 PM
