586,060 active members*
3,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > VFD in same enclosure with stepper drivers, ETC
Results 1 to 6 of 6
    Oct 2013
    543
    I've purchased a fairly large Hoffman enclosure and plan on putting all my electronics for a G0704 CNC conversion inside. There are two power supplies, a break out board, Intel NUC, smoother stepper and stepper drivers..AND, a Hitachi WJ200 drive. Has anyone had any issues with noise and/or problems with a drive in the same enclosure as all of the other electronics?
    Stuart
    Feb 2006
    7063
    Re: VFD in same enclosure with stepper drivers, ETC
    If everything it properly wired, and properly grounded, it will cause no problems whatsoever.
    Regards,
    Ray L.
    Oct 2013
    543
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Great..I'll proceed with that assumption, thanks.
    Stuart
    Aug 2008
    1186
    Quote Originally Posted by atomarc View Post
    Stuart
    As mentioned, it shouldn't be an issue but you should take extra care to properly utilize shielded wire runs and tie the drain wire to ground at the control side only to avoid ground loops. I would do this for all of the incoming and outgoing control runs.
    I have my VFD located in the cabinet and have never had a glitch or issue from it but I also followed automation directs guide using line filters on both incoming and outgoing power leads to the VFD and motor along with an EMI Filter. The line filters will help keep harmonic distortions or surges from the VFD from back feeding into and sensitive electronics connected to the same power source.
    I know some who have shipped those steps and gotten away with it and others who chased issues with noise. I think if your wiring runs are done correctly your be less likely to have issues without the extra parts, but I figured I'd go the way they paid it out from the manufacturer to be safe and give myself a chance.
    When routing wires (assuming you'll be using cable raceway to keep it neat and clean, is direct nothing less from an assist with build) take care to try and keep power lines sister as best as possible from control signal wires. I know it's not possible to keep them completely separated, but the conscious effort to minimize it will give you the best result. Keep all wire runs as short and direct as possible and DO NOT cool up extra wire length. For your computer to BOB use a quality shielded cable as short as possible and if you do have a little extra length for it tight rather that doing the extra up.
    Hope that helps! I'm assembling my lathe control cabinet right now. Get ready to have fun!! Lol. This is by far the least glamorous or fun part of the job and is tedious as can be, but it is reading rewarding to have a nice neat and clean cabinet!
    Sent from my QTAIR7 using Tapatalk
    Oct 2013
    543
    Chris,
    Thank you for your great suggestions...I'll keep them in mind when we get to the wiring stage.
    Stuart
    24221
    I have always mounted everything in the same enclosure, I even had two VFD's in the enclosure, both in operation simultaneously.
    Al.
    Albert E.
  1. Stepper motor&drivers,servo motors&drivers,motion control card CHINA factory
    By stepmotordriver in forum Manufacture Company Listing
    Last Post: 06-21-2014, 09:14 AM
  2. Stepper controller enclosure?
    By jviss in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2012, 09:04 AM
  3. AC Stepper Drivers
    By harryn in forum Stepper Motors / Drives
    Last Post: 07-02-2012, 10:15 AM
  4. Sherline mill enclosure/splashguard/drivers
    By cnc1000 in forum Benchtop Machines
    Last Post: 02-27-2010, 03:10 AM
  5. stepper drivers
    By Nilesh in forum CNC Machine Related Electronics
    Last Post: 06-23-2004, 02:05 AM
