586,104 active members*
3,510 visitors online*
    Feb 2017
    G92 thread cycle
    Hello, I am new at this site and I need some help. I am working in a part with a O.D.thread 4-40, I am using G92 to create the thread but for some reason the control is not picking up the G code. When it gets the time for the tool to perform the thread, looks like the tool just plunge in and out and go to the next tool. This is how my program looks like.
    M3S1=1200
    G0 X.5 Z.625 T3
    X.3
    G92 X.103 Z.825 F.025
    X
    X
    X
    X
    X
    X
    X
    G0 X.5 T0
    M1
    If anyone see something wrong or have any thoughts or advice, please let me know. I am more than welcome to hear from you. Thanks
    X have some values!!!!
    Machine is a k16 citizen
    Sep 2011
    261
    Re: G92 thread cycle
    Your code looks fine. Did the machine ever execute G92 successfully, or is this a recent problem?
    So the machine basically creates a groove, as in the tool goes down and up in X, but no feed in Z? I know on Fanuc controls, canned cycles like G80's, some G70's and some G90's are enabled or controlled by parameter settings, so if they are read but not executed (meaning you dont get an alarm like "Invalid G code") it may be a parameter setting.
    I'm pretty sure the K's have A Mits control... I'm not sure if the same logic would apply to them. I would ask your dealer for parameter settings related to threading cycles and double check them. That is some low hanging fruit to check off the list.
    CNC Product Manager / Training Consultant
    Feb 2017
    Quote Originally Posted by MCImes View Post
    Thanks for the replay. Yes I used G92 before. Today, this morning with clean, fresh mind I found the error. The problem was that I was milling before threading so I was using G19 to change plane settings, and I was not going back to G18 after milling process. Thanks for your replay and see you around👍
  1. Could use some assistance on G76 thread cycle
    By Dave Wojo in forum Daewoo/Doosan
    Last Post: 03-02-2014, 03:52 AM
  2. g76 thread cycle
    By warcnc in forum G-Code Programing
    Last Post: 02-03-2013, 11:32 PM
  3. G76 Thread cycle Haas SL-30
    By haaszard ahead in forum G-Code Programing
    Last Post: 12-14-2012, 03:26 AM
  4. G76 thread cycle in wasino lj-6mc
    By dkman in forum Fanuc
    Last Post: 09-27-2012, 09:05 PM
  5. G76 Thread Cycle
    By eliot15 in forum G-Code Programing
    Last Post: 03-27-2011, 04:01 PM
