586,444 active members*
3,235 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Setting 4-axis right work for rhino
Results 1 to 2 of 2
    Aug 2016
    3
    I use rhinocam for 4-axis processing.
    But I have problem with 4 axis parallel finishing. Problem that after first move form along axis Y, A coordinate is 0 grad. It rapidly moves on nominal speed to 357 grad. Throught my part. Today such mode cutted my part and I want to know, what can I do. I use linux CNC and I haven't adjusted move from 0 to 360 grad in minus. I need it work normally without such thing.
    G01 X0.0000 Y22.0000 Z117.0000 A0.000 F3000.Z111.0000 A0.000
    Y29.5000 A0.000 F1500.
    Y113.2500 A0.000
    Y118.2500 A0.000
    Y132.0000 A0.000
    Y135.1250 A0.000
    Y147.0000 A0.000
    Y154.5000 A0.000
    Y159.5000 A0.000
    Y270.0000 A0.000 <- hear starts a problem
    Y164.3750 A357.931 F5000. <- rapid move throught all part
    Y155.0000 A357.931
    Y137.5000 A357.931
    Y133.7500 A357.931
    In 4th axis parallel finishing > Cut pattern is setted: Along axis, Zigzag and Low to High. I use mach3 postprocessor.
    Aug 2016
    3
    Re: Setting 4-axis right work for rhino
    After a year after this post, I must say that problem was not solved. I suppose that it could be in postprocesosor. But I don't need it anymore.
  1. Replies: 4
    Last Post: 06-28-2010, 05:54 AM
  2. Setting Z axis with G92 work shift
    By venomgrrrl in forum Fanuc
    Last Post: 12-03-2007, 06:02 PM
  3. Rhino guy lookin for work
    By Dave98626 in forum Employment Opportunity
    Last Post: 02-03-2007, 09:31 AM
  4. setting rhino to default to inches?
    By CNC Darren in forum Rhino 3D
    Last Post: 09-12-2005, 03:51 AM
  5. RFQ - Rhino Modeling work
    By ViperTX in forum Employment Opportunity
    Last Post: 08-10-2005, 04:13 AM
