586,262 active members*
3,470 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Deckel Maho DMU 50 eVolution - Heidenhain Millplus
    Sep 2012
    6
    I've a Deckel Maho DMU 50 eVolution machine with Heidenhain controller. In this machine as soon I switch on I'm getting Z83 - Motor encoder warning error message. When I press Clear button this alarm will reset. I make Hydraulic on . When I try to reference the axes I'm getting E60 - Axis ready signal is low error message and I can't move any of the axes. I checked the Interface cards and found Ready( green LED) and SH2(red LED) are lit on each axes interface card. I checked Door interlock signals are ok. Please let me know how to check the other enable signals and how to solve this issue.
    Sandeep
    Oct 2008
    Hello,
    i have the same error on my machine, can you tell me how did you solve your problem?
    Thanks!
    Shejanov
    Aug 2018
    4
    Re: Deckel Maho DMU 50 eVolution - Heidenhain Millplus
    Hello,
    I have a DMU 50V with the same problem (E60 error), has someone fixed the problem?
  1. Deckel Maho DMU 50 MillPlus errors , needed Help
    By blasterpl in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-02-2016, 09:12 AM
  2. Dechel maho DMU 60 T (heidenhain millplus) diskete/disk fault
    By Greegor in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2016, 08:51 PM
  3. looking for Heidenhain Millplus expert
    By CAPTAINTP in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-28-2014, 01:13 AM
  4. Replies: 0
    Last Post: 11-22-2011, 04:23 AM
  5. Deckel Maho DMU 70 Evolution; Blum laser trouble
    By donuts in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-25-2010, 07:38 PM
