586,116 active members*
3,442 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > My homemade CNC router cant cut holes as it should? Anyone know what can be wrong??
Results 1 to 9 of 9
    Aug 2003
    72
    Hi all.
    A couple of years ago I built a large homemade CNC machine. It has served me well but one thing is not going as it should with it. I cant cut holes in the right shape. It has a quit heavy gauntry and Maybe that is the cause but think I need some help with this one.
    Circles get jagged in one side and round and nice in the other side. The different shaped hole edges are in the long axis (X).
    ANyone that can help me solve this? Using MACH3 and when milling wing cores with complex shape the result gets really nice. It is only when doing cutout files I get this. Maybe it is more information (points) when milling a wing foil???
    Thanks in advance, Kayaken
    Mar 2012
    192
    Re: My homemade CNC router cant cut holes as it should? Anyone know what can be wrong
    I would usually look at backlash if you are not getting round holes. The jaggies not sure, maybe lots of backlash and some sticktion. How rigid is the gantry? How much can you bend it if you have a hand size tool in the spindle and you give it a good yank?
    Jun 2005
    1730
    Check your ballscrew nuts. Looks like you have backlash on one of the axis
    Russ
    Aug 2003
    72
    Must be the X axis then which uses belts :/ maybe that is the reason. have been looking rebuild that axis
    Apr 2003
    540
    Yes you are either loosing steps due to a mechanical issue (loose coupler, pulley, belt, or binding due to misalignment/out of square etc) or because the motor speed or acceleration is to high/fast and the stepper is stalling. Check to ensure everything is good and tight. Something loose mechanically is normally the cause of such issues. If nothing is found, slow down your stepper speeds and acceleration and make some test cuts.
    A loose spindle/mount could also be the culprit so be sure and double check everything.
    Good luck.
    Aug 2003
    72
    Hmmmm Unfortionatly I have to low gear ratio on my X axis (far less then I wanted) due to the restricted area under the bed. I would have liked to make this higer gear ratio (more steps on each mm travel) and maybe that would solve the issue.
    Apr 2003
    540
    I know these types of issues can be frustrating. Out of round can also be Mach3 settings (IJ, CV Backlash etc) but the jagged edges look more like a mechanical issue. Incorrect drawing (how the cad is drawing segments, arcs and circles) can cause issues also... especially how your post processor handles the output. Specifically how it writes the gcode to cut arcs and radii.
    Jun 2012
    108
    Looking at the picture of the circle cut in the wood if side to side is the X axis and top to bottom is Y axis I would say the X axis is the problem. I would guess the ball screw is the the X axis base on the picture of wood. The uprights on the CNC look like wood and only 3/4 of an inch. If you push on the top of an upright I bet it move a lot ( the wood bowing ) I don't think the steps in the cut are backlash as basklash would be seen when motor changes direction. I would grab the Z Axis and see if there is slop/movement in the X or Y directions.
    Mar 2012
    192
    Quote Originally Posted by SteveWill View Post
    I assumed they were aluminum, and even then I was a bit suspicious of the rigidity.
  1. Homemade CNC Router
    By swassell68 in forum Videos
    Last Post: 06-24-2016, 02:47 AM
  2. 4x10 Homemade router table - CNC router parts
    By graphicideas1 in forum For Sale Only
    Last Post: 11-05-2014, 02:30 AM
  3. Router for homemade CNC
    By modric in forum Want To Buy...Need help!
    Last Post: 03-04-2013, 10:00 PM
  4. Here is my new homemade router
    By ahmed in forum CNC Wood Router Project Log
    Last Post: 12-09-2006, 07:17 PM
  5. And yet another first homemade router
    By Stevenpats in forum DIY CNC Router Table Machines
    Last Post: 11-16-2003, 12:28 AM
