586,068 active members*
3,876 visitors online*
    Nov 2013
    402
    Tapping. G84 or Long-hand?
    Hi guys,
    I just installed my PathPilot upgrade from the old Mach3, yesterday.
    I looked, but couldn't find the answer in my manual.
    Should I write my tapping cycles in PathPilot using G84? Or should I continue to write tapping cycles the old way, as I did with Mach3, Long-handed?
    I'm using the ER20 Tension / Compression tap holder.
    Jul 2016
    140
    Re: Tapping. G84 or Long-hand?
    I cant answer your question, but you should be aware of the G84 bug that was recently reported and is listed on Tormach's site (Issue # 1390). There's been more than a few broken taps because of it. More details here: https://forums.autodesk.com/t5/hsm-p...6900371#M12682
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    Nov 2013
    402
    UPDATE.
    Well, I finally got a paying job that required tapping.
    So, I also, finally, got an opportunity to answer my own question.
    I used the Conversational Tapping Wizard, and it spit out a G84 canned cycle program with a .2 second dwell (P.2)
    AH-HA!!!
    So PathPilot DOES support G84 canned cycles!
    YAY!!!
    No more Long-Hand programming for me.
    PS- It ran and tapped like a dream. MUCH better than the old Mach3.
  1. Long hand post for an integrex
    By lenny09 in forum GibbsCAM
    Last Post: 11-20-2014, 03:07 PM
  2. Haas TL1 IPS or Long hand or DFX?
    By cpmfastools in forum Haas Lathes
    Last Post: 04-24-2013, 12:34 AM
  3. Hand tapping
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 11-06-2012, 09:45 PM
  4. Left hand tapping
    By Get lucky in forum G-Code Programing
    Last Post: 05-28-2012, 04:10 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
