586,062 active members*
4,429 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Romi Lathes > Bridgeport Romi EzPath Lathe / Rotary Phase Converter
    Apr 2011
    21
    Cool Bridgeport Romi EzPath Lathe / Rotary Phase Converter
    I just picked up one of these lathes dirt cheap, it is 240 3 phase power, I do not have 3 phase power where I live. Can you run this lathe off of a rotary phase converter or should I get a VFD drive, if so how big of a VFD will I need? Thanks Guys.
    Oct 2010
    Re: Bridgeport Romi EzPath Lathe / Rotary Phase Converter
    Did you get your power situation worked out?
    Rotary phase convertor or VFD?
    I'm having trouble getting my EZ Path1 powered up and running on a rotary phase convertor.
    What year is yours?
    Thank you!
    Apr 2011
    21
    Quote Originally Posted by xtreme fab View Post
    What year is yours?
    Thank you!
    it is a 1996, I haven't had a chance to do anything on it yet.
    Apr 2011
    21
    did you get your lathe up and running, no luck on my end
  1. Running Bridgeport Interact 1 series 2 mill on a rotary phase converter
    By Titchmarsh in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2016, 02:03 AM
  2. Bridgeport/Romi EZPATH Schematics
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 06-25-2011, 12:00 AM
  3. Rotary phase converter for Bridgeport 2J Series 1 KM-1 2HP setup?
    By modernprecision in forum Bridgeport / Hardinge Mills
    Last Post: 07-02-2007, 12:43 AM
