586,036 active members*
4,427 visitors online*
Results 1 to 3 of 3
    Oct 2003
    155
    Question 3040 5 Axis "Z" axis reach/travel?
    Hoping someone here can answer this by measuring their machines "Z" Axis travel?
    Wanting to know what the "Z" distance is in inches (MAX n MIN) from the center of the "C" Axis when the "A" Axis is at + or -90 deg to the tip of the spindle nose/collet.
    Looks like the "Z" Axis can be adjusted on the column and the spindle can be adjusted in the spindle clamp also.
    I know the add states 150mm or 5.9" but hoping to get a REAL number. Maybe some pics also...
    Thanks, MM
    http://www.automationtechnologiesinc...4/08/3040A.jpg
    http://www.automationtechnologiesinc...router/hy-3040
    Apr 2004
    5737
    Re: 3040 5 Axis "Z" axis reach/travel?
    Have you tried measuring it?
    Andrew Werby
    Website
    Oct 2003
    155
    I do not have the machine, yet? Just trying to get some real numbers to see if it will work for what I need it to make?
    Attachment 352396
  1. Need help working out feed rate for "C" Axis and "Z" axis simultaneously.
    By Jonaldhinio in forum Australia, New Zealand Club House
    Last Post: 08-12-2014, 09:27 AM
  2. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. X3 extended y-axis travel (7.75" vs 5.75") ?
    By nullbert in forum Benchtop Machines
    Last Post: 10-05-2008, 06:28 PM
  5. "Actual" max Z axis travel?
    By Otter1 in forum Tormach Personal CNC Mill
    Last Post: 09-15-2008, 11:12 PM
