586,588 active members*
2,422 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Speeds and feeds for 1018 steel are chipping my endmills!
    Jul 2016
    18
    I'm using GWIZARD calculator to get my speeds and feeds. Haven't had any problems until last night. I tried to cut some 1018 hot rolled steel at 2mm deep with a half inch thick, four flute TiAIN coated carbide endmill, square/ flat cut. I was going at 3250RPM and 891.6 mm/minute.
    I broke the first end mill, and chipped the hell out of the second. I'm using Fusion360 for all my cad/cam, and was using the 'adaptive roughing' strategy to remove material, which means the tool wasn't fully slotting the steel all of the time.
    Any ideas what went wrong? Should I be using specific tool paths?
    Jul 2005
    12177
    Re: Speeds and feeds for 1018 steel are chipping my endmills!
    You may be going a bit fast. At 3250 rpm with a four flute cutter taking .001" per tooth you need about 18ipm, i.e. About half the speed you have (if my math is correct).
  1. Speeds and feeds for steel
    By lead-slinger in forum Mechanical Calculations/Engineering Design
    Last Post: 01-28-2012, 06:22 AM
  2. Speeds and Feeds for ASTM A-500 Grade B Steel
    By nfrees114 in forum MetalWork Discussion
    Last Post: 02-26-2010, 05:05 AM
  3. Feeds and Speeds for small endmills
    By flathead in forum MetalWork Discussion
    Last Post: 10-22-2009, 07:38 PM
