586,069 active members*
3,410 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Bar puller programming?
Results 1 to 8 of 8
    Jul 2004
    100
    I am wondering if there is a better way to program multiple pieces.
    I have a MPF that calls an SPF multiple times.
    The SPF does the actual machining.
    This works OK, but I don't like the way I have to access the SPF for editing and saving,
    Editing and saving the MPF is easy while in the RUN mode,
    but to get to the SPF I have to got to PROGRAM, SUBPROGRAMS, choose the SPF, edit it, then page down through the WORKPIECES to save it.
    I don't have a bar feeder, but use a bar puller with these programs.
    Regards, Ray
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
    Re: Bar puller programming?
    I do it the other way, I have my machining in the MPF file & call the sub program for the bar pulling. Then I just get the MPF file to loop however many times I need it to which is usually the number of components I can get out of a length of bar. This way you can edit the mpf as you'd normally do when running & only need to load the SPF(Unless you want to edit the lengths the bar puller is using etc)
    Jul 2004
    100
    Quote Originally Posted by atmosports View Post
    How do you get an MPF file to loop? I haven't been able to do that.
    Regards, Ray
    The easiest way is between the M05 &M30 at the end of the MPF, insert the following:
    @100 K-5
    The @100 command makes it return to the start of the program. The K-5 part tells it which line to start from so in this can Line5 or N5, if you use @100K-15 it would start on line 15 or N15
    I then set the parts counter to the same amount of components I get out of a bar so it'll run the bar then stop.
    Another way of doing it is using the R48/R49 parameters
    To do this you'll need to add more lines into your program: Sample as below
    N5 G18 G54 G90 G71 G95
    N10 R49=4
    N11 R48=1
    N15 R48=R48+1
    N20 G92 S2000
    N790 G90
    N795 M55
    N800 @123 R48 R49 K-15
    N805 G90 G58 Z0
    N810 M30
    the @123 tells the control that when r48 is less than r49 it must repeat the MPF. When R48 is equal or greater than R49 it will continue to the end of the program, the K-15 tells it which line to start on. R49 is the number of repeats in this case above it's 4
    This works on all our lathes running 840c Controls, I haven't had to do it on the 840d controls yet but I'd imagine it'd be similar as most things are the same
    Jul 2004
    100
    Atmosports,
    I will try it tomorrow. I tried in the past with something like this:
    N10
    @100 K10
    M30
    But it didn't work. I suppose @100 K-10 will do the trick, no?
    Regards, Ray
    Mar 2016
    325
    No "-" before on the K parameter means that indicated block number is beeing seek after this line.
    Jul 2004
    100
    Atmo and all,
    Success! I am using the parts counter to stop when the bar is finished. Thanks for all your help! - Ray
    N10 (initial bar puller to set start point)
    N20 (bar puller to pull stock to position)
    M55
    N30 (form tool)
    N40 (thread)
    N50 (knurl)
    N60 (part)
    @100 K-20
    M30
    Mar 2014
    Thanks RBrandes...good stuff to know!
  1. Bar puller programming
    By FUN4ME in forum Haas Lathes
    Last Post: 02-27-2017, 11:12 AM
  2. Bar Puller
    By BCARL in forum Cincinnati CNC
    Last Post: 02-27-2017, 11:06 AM
  3. Help programming a bar puller
    By Home Machinist in forum Haas Lathes
    Last Post: 09-13-2012, 01:42 AM
  4. Programming a bar puller in X2 on a lathe
    By bob1112 in forum Mastercam
    Last Post: 01-06-2009, 05:05 PM
  5. Bur Puller programming
    By Genie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2006, 01:48 AM
