586,104 active members*
3,371 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CANT GET CITIZEN M20 TO RUN SET AMOUNT OF PARTS
    Feb 2008
    3
    Hi
    I have a '96 citizen M20 with a Mitsubishi control. im new to swiss style machining but im getting the hang of it. Only problem i have is keeping the machine running continuously. im using the gang tools for turning and milling and the turret for drilling a hole in the face of the part. After its done machining the part the machine stops at the M2. I'm only using line $1 (G711 & G712). I cant figure out how to make the machine run continuously for a set amount of parts. Any help would be appreciated.
    Feb 2011
    353
    Re: CANT GET CITIZEN M20 TO RUN SET AMOUNT OF PARTS
    I'm running a-32's with the mitsubishi control
    my guess would be that all the program lines must be used even if your program is for $1
    Try putting an m99 after the m2's
    and you should have a parts counter to control the number of parts before the control will alarm out on the parts count
    Feb 2008
    3
    Thank you for the reply but I already have an M99. I have the counter set to run 10 parts but it always stops at the M2 after one part. The machine just sits there like its waiting for something. Im guessing my program is wrong but I cant figure it out.
    Here is my program
    LINE $1
    G113 M6
    G50 X-.120 Z.377
    G99 M3 S1=5000
    G0 Z-.05
    G710
    G711
    M52
    T1100
    CALL UP BASKET (T20) / MOVE IT INTO POSITION
    THEN CUTOFF PART
    THEN
    G712
    G0 X2.0 T20
    T2500
    M56
    M5
    G999
    N999
    M2
    M99
    LINE $2
    G710W1
    G710W1
    G730
    G999
    N999
    M2
    M99
    LINE $3
    G710W1
    G710W1
    G730
    G999
    N999
    M2
    M99
    304
    You are in "Cont" mode I assume? Thats the only way it would ignore the M2.
  1. NEWBIE to Citizen - G32 thread whirling on Citizen L520???
    By jmonty in forum CNC Swiss Screw Machines
    Last Post: 09-07-2013, 06:50 PM
  2. Looking for Parts 1992 Citizen L20
    By RussellSt in forum CNC Swiss Screw Machines
    Last Post: 08-21-2013, 09:32 PM
  3. Need help writing program for Citizen E2-32 for long parts
    By gizmo_454 in forum CNC Swiss Screw Machines
    Last Post: 12-16-2011, 07:17 PM
  4. Citizen L720 parts main spindle
    By jack moore in forum Want To Buy...Need help!
    Last Post: 02-11-2011, 05:39 PM
  5. Citizen A20 Parts Counter
    By danrudolph in forum CNC Swiss Screw Machines
    Last Post: 03-16-2010, 05:31 PM
