586,655 active members*
3,339 visitors online*
Results 1 to 8 of 8
    Oct 2014
    10
    Moving VMC 15
    I'm looking at purchasing a VMC 15 as I think it will be a good fit for me. I've got an 8000 lb forklift but my forks are only 36". What size of fork would I need to properly unload this? The machinery salesman suggested I just buy a set of extensions. That seems a little questionable since I'm guessing I should get a set of 72" forks.
    Aug 2015
    368
    Re: Moving VMC 15
    Fork extensions work just fine in general.
    Sent from my SM-G900V using Tapatalk
    Dec 2004
    126
    Re: Moving VMC 15
    I just moved a 15 and 15xt with 48" forks from the back of the machine ,,, you would need longer ones from the front ... you can just use box tube for extensions ....just double check that they fit in the fork pockets on the fadal and you will want some wood so the machine can not slide back on the forks and crush the back cabinet
    Oct 2014
    10
    Re: Moving VMC 15
    Quote Originally Posted by D.D.Machine View Post
    The machine I was going to buy fell through, but I'm still looking for a machine and am hoping to find a 15xt for a reasonable price. Can you tell me what size the fork pockets are? That way I can be ready when I find a machine.
    Jan 2015
    417
    Re: Moving VMC 15
    the lifting pockets/ Steel square tubing inner dimensions are 6.5 x 3.5 also go to Flint Machine and download the manuals and everything else you need for the machine Free downloads https://flintmachine.com/fadal.php
    - - - Updated - - -
    Also there are a few 15xt on ebay
    Oct 2014
    10
    Re: Moving VMC 15
    Thanks for the replies.
    What has to be done to a VMC 15 before shipping? Does the counterweight need pinned or what?
    Nov 2003
    287
    Re: Moving VMC 15
    counter weight pinned and head fastened to table via bracket. If your going through a 7' high overhead door, you have so remove z axis motor and unbolt cable track and lay on side.
    Aug 2015
    368
    Re: Moving VMC 15
    Quote Originally Posted by zekeymonkey View Post
    Make sure the pins go all the way thru.
  1. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  2. Design Options: Moving bridge vs. Moving Cross Beam
    By martin_05 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 08:20 PM
  3. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  4. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
