I was playing around with the C Axis and the Custom Siemens Mill-Turn Post for Fusion and discovered a few things. To make the post processor work in the posted code you must: Remove all ref’s to SETMS Remove G97 M2=xxxx Remove any reference to “Y” axis Remove “TRANSMIT” and “TRAFOOF” In Fusion: Keep Smoothing ON and Tolerance Loose I also deleted a lot of the C axis moves that weren't associated with another move, as the post seems to produce micro motion of the C axis. I attached the code I am testing to produce the video. Also I attached the post processor in case anyone wants to edit it. Here is the C axis actually working: I am not certain if the jerkiness is due to the programming (most likely).
Thats pretty cool. Thanks for sharing that.
Im guessing that since I know knothing about CNC not to buy the machine so if ive to delve into the fiddle with it to make it work ?
View Tag Cloud
Forum Rules
