586,441 active members*
3,756 visitors online*
Results 1 to 6 of 6
    Jul 2003
    71
    5 Axis Alignment
    Does anyone know if thier is a setting that allows you to re-align the C axis for every 90 degrees of rotation.
    Reason I am asking we have a 5 axis machine that is running a Centroid controller and our head is not perfectly aligned with the c axis.
    In past controllers such as Siemans thier was what I believe was called C axis Wind Up. Where you can adjust the C axis for every 90 degrees so it doesn't through off your x or y.
    Any suggestions or help on this matter will be great.
    Chris
    Feb 2006
    992
    Is it 5-axis index or full 5-axis?
    Anyway, with 5-axis index easier to fix with a ball gage, but full fifth the only I can thinking of is indicate the table straight.
    The best way to learn is trial error.
    Feb 2007
    664
    Quote Originally Posted by Tazzer View Post
    Chris
    I'm not clear on what you mean by
    also is you "c" axis laying on the table rotating around your "z" axis
    Jul 2003
    71
    It is a full 5 axis machine.
    The C axis wraps around the Z. As the C turns 90 degrees it throws off the X and Y by .015 then if I go to 180 degree it is off .023.
    I used to run a Seimans 5 axis before this centroid and thier was a C axis windup setup that allowed you to teach the controller if the head alignment was off you can go in and enter how much your x and y like you would with cutter compensation.
    Here is a pic
    Feb 2007
    664
    definetly sounds like a "c" axis mapping problem
    I'm not familiar with your control so i can't tell you if it's map able or not
    you can call the control manufacturer and they should be able to help you
    Feb 2007
    664
    does the error add up in both directions
    or one way adds up and the other subtracts
    if both directions add up you may need to adjust your gains(first check for backlash in the "c" axis)
  1. x-axis ball screw alignment.
    By grinderdust in forum Benchtop Machines
    Last Post: 12-28-2006, 12:44 AM
  2. Machine Alignment
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 09-23-2005, 12:52 PM
  3. Setup alignment
    By ozzie34231 in forum MetalWork Discussion
    Last Post: 08-25-2005, 01:24 AM
  4. x-axis alignment
    By FLUTE HEAD in forum Vertical Mill, Lathe Project Log
    Last Post: 07-10-2005, 03:05 PM
