We have added few interesting features to recent deployment at OnCreate3D portal.
Sharing projects with others:
OnCreate3D, First Full Cloud CAM app, makes life easy for Design Engineers & Machinists, by allowing to share their project(s) with other users (operators, decision makers etc.) Machinist seating at his remote office can create NC Files for CNC Machines in his production facility. He can simply share his project with operator who can download NC File and run the machine. The machine that Machinist programmed for is busy? No problem, operator can configure POST to output new NC File for different CNC Machine. Create toolpath operations only once and use it for different locations, different machines multiple times. Machinist doesn't want operator to change his toolpath operations? Simply give READ permission. Machinist wants to allow operator to edit toolpath parameters to suit machining conditions? Give him WRITE permission.
Toolpath simulation:
OnCreate3D has introduced toolpath simulation to visually check for correctness of toolpaths before downloading NC Files. You can play/Pause any time, you can speed up/down anytime. Although it is simple simulation for time being, we are working on showing updated stock after every operation. The feature is coming soon. Stay tuned.
Customizing POST parameters:
Users can now customize POST parameters and generate correct sequence of commands in NC File.
User Interface:
We constantly strive to make it better. New icons for toolpaths depict the purpose better than before. Operations tree view is now resizable and can be moved on graphics window for your convenience.
We are working on bringing nesting to OnCreate3D. Stay tuned.
Check out latest deployment at www.OnCreate3D.com. Sign-in, it is FREE until June end 2017.
