Question; I have a 4'x4' plasma table running on Mach3. We are setting the table up and trying to get to as close as perfect as possible before we start cutting metal. In Correl draw we made a 10" circle with the center cut out, so a donut. The border of the circle is 1' We have a pen attached to the torch and are drawing on a piece of paper. There are small flat spots on the circle and the lead-in, lead-out lines are not lining up exactly (within about 1/32") Through experimentation to see where these flat stops are coming from I override the feed rate in Mach3 to the maximum speed and noticed that the machine creates these flat stops at cardinal points on the circle. I've turned the constant velocity up to the highest setting, but still there's a slight pause.
Is this something that can be adjusted in Mach3 or Sheetcam?
