586,449 active members*
3,244 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Virtually unwinding 4th in Post Processor
    Jan 2012
    14
    Hello all,
    I'm doing a lot of rotary 4th milling and my A axis needs to unwind a few times in long jobs. I'm using a HAAS TM -3P and the exported Bobcad code is below. This unwind takes a few minutes but I can go in manually and use the commands:
    G91 G28 G00 A0.
    G90
    G92 A(Whatever value I need).
    In place of the unwinding process. Is there a way to make the post processor do this for me?
    Thanks!
    Original Output:
    N13865 X-1.2799 Z3.6561 A-9993.762 F3482.2216
    N13866 X-1.2798 A-9994.212 F9999.
    N13867 X-1.2792 Z3.6563 A-9996.012 F3482.208
    N13868 X-1.2785 Z3.6561 A-9997.812 F3482.2091
    N13869 X-1.2782 Z3.6558 A-9998.712 F6964.5613
    N13870 X-1.2781 Z3.6557 A-9999. F9999.
    N13871 G00 Z13.6557
    N13872 A-9954.
    N13873 A-9909.
    (AND SO ON)
    N13965 A-5769.
    N13966 A-5724.
    N13967 A-5679.
    N13968 G01 G94 Z3.6557 F400.
    N13969 G93 X-1.2778 Z3.6563 A-5680.063 F5899.6854
    N13970 X-1.2771 Z3.6562 A-5681.863 F3482.198
    N13971 X-1.2765 Z3.656 A-5683.663 F3482.3207
    Dec 2008
    4548
    Re: Virtually unwinding 4th in Post Processor
    You can make the post output that reset code, but it wont be usable in "The middle" of code, because the A would resume at the next rotation value.
    You could do the calcs with length and stepover to realize "how much 4th you can rotate before an unwind is needed" then use the start and end points in the rotary feature to "only do what 1 go will allow". Then the post can output the reset, then the next feature starts off with the next start and end points?
    You can also go into the machine definition under current settings and set the proper limit of the rotary axis, and the posting engine wont let you post out past the rotary limits.
    Not what you were looking for but that's all I got...
    Jan 2012
    14
    Thanks again BurrMan,
    I was thinking along the same line as far as the machine limits. I'll see where I get. I have another question about rotary leads out, maybe you'll be able to answer that one too
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. 4th axis unwinding
    By Paul Goddard in forum Mastercam
    Last Post: 04-07-2010, 11:51 AM
  3. Waterjet Machine Cuts Virtually Anything
    By Jetedge in forum News Announcements
    Last Post: 08-28-2009, 03:00 PM
  4. Waterjet Cuts Virtually Anything
    Last Post: 08-10-2009, 03:46 PM
  5. Unwinding a toroidal, what tape?
    By Greolt in forum CNC Machine Related Electronics
    Last Post: 03-30-2007, 03:43 AM
