586,100 active members*
2,627 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > Methods and apparatus for pre-planarizing cnc axises
    Apr 2006
    1016
    Hope to to have all the "great cnc builder" to post how they
    pre-planarizing there axis in this post, pictures are very welcome
    cheers to all there hard work
    Aug 2005
    6
    Hi!
    To build my new (420X760X180 mm) fixed gantry mill, I used a very simple methode to pre-planarize my axcises. I let by a joiner's shop cut from 19mm thick board two jigs. One for axis X and one for axis Y. These jigs had the exact measurement between the respective 25 mm dia axises. Under these jigs i fixed with screw 50 mm wider boards. Then I cut rectangle-form holes in this assemblies for positioning the alu blocks of the teflon bearings. Then I fixed the axis roads with rubber band to the jig assembly.Because the CNC saw of the joiner's shop made an exact, paralell cut and because the under board of the jig assembly did not allow the axis roads to move or fall down, I got a perfect axis assembly to fix the roads to the frame. You can modify this apparatus so, that it can position the leadscrew too.
    cheers G. Merkel
    (Budapest, Hungary)
    Feb 2007
    532
    I'll bite..
    From the first reply, I asume 'pre-planarizing' means getting the ways lined up accurately?
    (there's no such thing as a dumb question! )
    Aug 2005
    6
    Yes, I anderstood so. It was a big problem of the newbies of our CNC community
    (www.hobbycnc.hu)
    Apr 2006
    1016
    Method to square a Gantry?
  1. What methods did you use for sliding motion
    By widgitmaster in forum Polls
    Last Post: 07-04-2013, 01:04 PM
  2. SIGN Making methods?
    By esmiller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-23-2008, 04:49 PM
  3. Replies: 12
    Last Post: 01-09-2007, 07:42 PM
  4. Precision layout methods
    By pminmo in forum MetalWork Discussion
    Last Post: 08-21-2005, 02:21 AM
  5. Simple CNC marking/writing apparatus?
    By kywoodwrkr in forum DIY CNC Router Table Machines
    Last Post: 03-03-2005, 03:58 PM
