586,065 active members*
4,301 visitors online*
Page 7 of 10 56789
Results 121 to 140 of 190
  1. #121
    Aug 2007
    55
    Re: New MODBUSEZ SetUp Plugin For UCCNC
    For anyone interested, here are the working Nowforever D100 VFD (same parameters as E100 FW 1.3) settings for modbus (modbusez plugin UCCNC)
    parameter - default -> new
    p000 - 1 -> 2
    p001 - 0 -> ok
    p002 - 2? -> 6
    p055 - 1 -> ok
    p056 - 2 -> ok
    p057 - 0 -> ok
    UCCNC settings for actual spindle speed DRO:
    UCCNC Sact label setting 870 (default) -> 2451 (new)
    The rest is as in the "screen shot" below (select com port from your installation).
  2. #122
    Jun 2015
    943
    Thanks for sharing.
    I'm now using analog voltage for the VFD control, but if I built a next machine then I will use this information, thanks.:wave:
  3. #123
    Mar 2010
    813
    Hi Ron,
    Sorry for the late response but work been keeping me from comp.
    I read through here and pm and see you answered all of your own questions. I was happy to read you got the plugin working easily and appreciate you posting back with your settings to help others.
    Dan
  4. #124
    Aug 2007
    55
    Quote Originally Posted by Dan911 View Post
    Hi Ron,
    Dan
    No problem Dan. Thanks for putting the plugin together
    Sent fra min SM-A520F via Tapatalk
  5. #125
    Nov 2014
    Hello,
    I would like to try using this plugin but I seem to have a problem with the "Serial Port Setup Data" fields not saving. I'll set the COM, Baudrate, Bit information and hit the "Save All Settings" button and exit the Configure screen and close out UCCNC. When I restart UCCNC and go back into the Configuration screen the Serial Port Setup Data fields are blank. The data in the Spindle/Motor Setup and Modbus Setup fields all seem to have saved just fine.
    By the way I'm using the 2017 Screenset.
    I don't have much experience with this so I'm hoping someone can point me in the right direction as to what is causing this error?
    Thank you!
    PT
  6. #126
    Mar 2010
    813
    Hi PT,
    It isn't a error I just neglected to show saved port settings. If you saved you can go to your pro file and confirm settings used.
    To eliminate any more confusion with com port settings I updated plugin to show com port saved settings when returning to the ModbusEZ configure.
    To use with 2017 screenset you need to edit the RPM field number, instructions below....
    11. Goto CONFIGURATION / GENERAL SETTINGS / Edit screen. Go to your run screen (Shift + run), click on your "RPM" feild , choose "Selection tab"
    and change the labelnumber from "870" to "2451", than click apply settings, click on File tab on top of window and click "Save screenset".
    Dan
  7. #127
    Dec 2014
    14
    Hi.
    Just started to play with my new UCCNC setup and Nowforever VFD. Everything went well, motor was acting as expected but suddenly VFD runs like 10x less speed as commanded = S3000 = 50Hz is actually running only 5Hz. Any ideas what went wrong?
    EDIT. Works now but no idea what was the reason....
    Sact 870 => 2451 does not work either.
  8. #128
    Mar 2010
    813
    Quote Originally Posted by Jerkko View Post
    Hi.
    You either unchecked frequency resolution in ModbusEZ configure or changed the resolution in VFD settings.
    You only have to change RPM field labelnumber from 870 to 2451 if using 2017 Screenset.
    Dan
  9. #129
    Jul 2013
    11
    Good Evening Dan,
    I've just purchased a HY GT series VFD ( GT-2R2G-4 ) and would like to ask if your HY plugin would work with this new type GT series?
  10. #130
    Mar 2010
    813
    Quote Originally Posted by attila0216 View Post
    Good Evening Dan,
    ModbusEZ plugin will work for the HY GT Series, there's settings in the manual for it. If any questions don't hesitate to ask.
    Dan
  11. #131
    Jul 2013
    11
    Thank You very much Dan!
  12. #132
    Feb 2008
    482
    Good Evening Dan,
    if you cant get serial comunication working- i found the gt series needed 2 wired soldered links moved. i have details
    so much to learn, so much to pass on.
  13. #133
    Aug 2011
    68
    Just wanted to say thanks Dan911. You are awesome.
  14. #134
    Mar 2010
    813
    Quote Originally Posted by ack1 View Post
    Thank you for the kind words ack1, glad you found the plugin helpful.
    Dan
  15. #135
    Mar 2010
    813
    Hi Milosh, Sorry for delayed response but if I don't see any new post in threads I don't sign in and know of new pm's. There also can be others that could help or when you find your solution can help others. Also I can't post images in PM's the can help.
    Did you try the settings in manual?
  16. #136
    Sep 2006
    32
    Dan, thanks for response.
    Yes I did it first, and didn't work.
    This config turns spindle on but there is no speed control (frequency is always 196 Hz)
    Attachment 395880
    This config doesn't turn the spindle on.
    Milosh
  17. #137
    Mar 2010
    813
    Hi Milosh,
    Keep the settings that's turning spindle on off using single coil. Don't worry about ccw for now. Try unchecking frequency resolution, save and restart UCCNC.
  18. #138
    Sep 2006
    32
    Hi Milosh,
    Hi Dan,
    Unchecked feequency resolution, but still no luck. Only on off. No speed controll. Just to be clear, when I use the button to turn the spindle on, I shoud be able to overide the spindle speed with plus or minus sign. Unfortunaltely, numbers on the screen are changing but not the spindle rpm.
    Milosh
  19. #139
    Mar 2010
    813
    Hi Milosh,
    Please try plugin I attached and use settings in pic. If still not working change Frequency address/coil to 0000 and try again. Make sure you restart UCCNC after changes.
    Dan
  20. #140
    Sep 2006
    32
    Hi Dan,
    I loaded ver 16 and tried with different frequency addresses (0000 and 0001) and there are no changes. No rpm control. And I even tried to turn off frequency resolution and checked multiple coils. But no luck again.
    Today was a busy day and tomorrow I may try to use different computer.
    Still don't understand where the problem is. Is it that we have frequency register address wrong, or is it something else? I think that register address should be 0000h for 0001h register number. Is there something in the UCCNC that may be wrong set (checked spindle setting and PWM is checked, spindle pulley is not checked)?
    Milosh
Page 7 of 10 56789
  1. PCB Autoleveler Plugin for UCCNC
    By cahit in forum UCCNC Control Software
    Last Post: 11-22-2019, 01:41 PM
  2. Uccnc - plugin creation - pendant
    By robertspark in forum UCCNC Control Software
    Last Post: 09-02-2017, 09:42 AM
  3. Waiting for VistaCNC plugin for UCCNC
    By iflyinverted in forum UCCNC Control Software
    Last Post: 05-25-2016, 04:20 AM
  4. UCCNC units and setup
    By skcncx in forum UCCNC Control Software
    Last Post: 12-30-2015, 04:46 PM
  5. SX-3 Mill Conversion, ESS Plugin Setup in Mach3
    By mrpackethead in forum X3/SX3/G0619/G0463
    Last Post: 02-04-2014, 10:43 AM
