586,106 active members*
3,162 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > difficulty grasping certain things...well..most things..
    Sep 2014
    66
    Hi.
    After playing on a friend's machine and reading lots of articles and practising on trial editions of lots of programmes I suppose I'm learning stuff, but in general terms.
    The specific problem that bamboozling me at the moment is postprocessing and using DSP.
    So I do the machine path by picking the post processor from a list, calculate preview and save the toolpath on a usb and run it using the Rich Auto AR51.
    How do the specific postprocessor the DSP, and the machine model 'fit' together?
    Is the DSP strictly neutral? I mean will it run any gcode on any machine or does it have formatting and other factors of it's own that need attending to?
    What are some of the factors machine specific factors that affect postprocessing? I know there is a variety of file extensions but I have no idea why.
    I'm worried that all my time & effort learning stuff on my friend's machine is going to be useless if I eventually buy something else.
    Is that a reasonable concern or is it a setup issue that is not too onerous?
    Rob.
    Sep 2006
    6463
    Re: difficulty grasping certain things...well..most things..
    Hi....all CNC mills, ,lathes and routers run with XYZ as the direction the spindle or table moves in,
    the table in a column mill moves left to right and is called the X axis.......towards and away from ther column is called the Y axis.....up snd down is called the Z axis.
    A CNC router mas the table as the Y axis moving away and towards you as you are standint at the end..........the spindle is attached to a saddle that moves on the crossbeam and this is the X axis........the spindle also moves up ans down on the Y axis and this is called the Z axis.
    I can't say for a CNC lathe as I'm not into CNC turning.
    If you learn how a mill or router works with hands on experience, then the rest will come naturally......google Utube and see machines in action.....they're all the same in the end.
    Any CNC knowledge is good knowledge, but you need to do some in depth learning to get the full spectrum......a little learning is a dangerous thing.......believe me.
    Ian.
  1. When things come together
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 08-26-2012, 07:11 AM
  2. Can anyone help with these things
    By thammy in forum Community Club House
    Last Post: 08-03-2012, 05:41 PM
  3. About to buy the PC 770 if things go right.
    By cjdavis618 in forum Tormach Personal CNC Mill
    Last Post: 01-10-2011, 12:27 AM
  4. need help with a few things.
    By BeeleJuice in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2006, 04:32 AM
  5. Things to cut
    By joecnc2006 in forum DIY CNC Router Table Machines
    Last Post: 06-29-2005, 10:20 PM
