586,051 active members*
3,851 visitors online*
    Nov 2013
    12
    Blowing Fuses?
    I have a couple of the X900 machines and both of them have been blowing fuses.
    The first unit melted an e-stop switch and then started to blow fuses to the point the machine wont do more than power up and blow a fuse.
    Our second machine seems to have melted the main power switch and is also blowing fuses.
    Any pointers would be great!
    Re: Blowing Fuses?
    Tim, what do you have plugged into the convenience outlets in the back of the machine. These will only handle low amps. Melting the power switch, the power cord fuse, etc have all happened due to trying to run fans, coolers, etc from those outlets. I recommend that you don't use them at all.
  1. Keep blowing fuses
    By bujaman in forum Maintenance DIY Discussion
    Last Post: 01-29-2014, 07:26 PM
  2. Blowing 20a fuses!
    By fgwilson99 in forum Community Club House
    Last Post: 04-28-2011, 02:13 AM
  3. Blowing Z axis fuses on 6MB
    By moldmker in forum Fanuc
    Last Post: 08-30-2008, 05:34 AM
  4. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
