586,693 active members*
2,826 visitors online*
Results 1 to 7 of 7
    Feb 2017
    18
    New Machine & New to Mach3
    I built a DIY/CNC using a Novusun NVEM motion controller, NC switches X/Y connected in series and Mach3(demo). The machine jogs well on all axes and the switches work well as limits. However I have some issues that I can't seem to get by:
    1) I have Auto Limits Bypass enabled but when I trigger any of the limit switches I can't reset Mach3 in order to back-off.
    2) I can't zero machine coordinates unless I power off controller/motors, position the axes manually and start Mach3 without device connections to zero coordinates. I have tried the zero/send to DRO options, no difference.
    3) I wanted to be able to use the X/Y switches as both limits and homing, but when I ref-all-home, the X axis moves towards the correct switch but when it triggers, it resets Mach3 and I'm back on issue #1.
    Any help would be appreciated.
    35538
    Re: New Machine & New to Mach3
    1) Your motion controller may not support that function. Contact the manufacturer.
    2) the only way to zero machine coordinates is to ref (home) the axis.
    3) Noise is triggering the limit during homing. If the controller has any debounce or noise filter settings, try increasing them.
    Feb 2017
    18
    I appreciate the quick response. Well the documentaion for this controller is really bad and support is non existing. Mach has a debounce setting, I'll play with that to see if it improves noise issues.
    Is the issue with reseting Mach3 after a limit fault a controller issue as well or is this a Mach3 setting that I may be missing ?
    35538
    There aren't really any Mach3 settings. Just the two override options, manual and automatic. If they don't allow you to jog off the limit, my guess is that's it's a controller issue.
    Debounce shouldn't have any affect, as it's for noise on the parallel port.
    Feb 2017
    18
    Well you are absolutely correct. I played with that this morning and arrived at the same conclusion, this Novusun motion controllers are GARBAGE and at $130 for 4 axis expensive at that.
    thanks for your insights, I'm just going to the system working with PP and think about the next upgrade carefully....
    35538
    I think that all of the chinese motion controllers have issues.
    Feb 2017
    18
    looks like it. I'm glad that th9s one turned out to be a freebe, otherwise id be pissed right now.
  1. Machine not always following Mach3
    By MP-40cal in forum DIY CNC Router Table Machines
    Last Post: 12-10-2016, 11:44 AM
  2. Can my machine use Mach3?
    By archlab-unav in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2014, 12:00 PM
  3. Looking for Chinese Machine w Mach3
    By restos in forum Chinese Machines
    Last Post: 10-31-2011, 03:58 AM
  4. Mach3 for ID grinding machine
    By shridhar in forum Mach Wizards, Macros, & Addons
    Last Post: 02-20-2011, 09:28 AM
  5. what machine does Mach3 G code come from?
    By chevdrgtrk in forum Mach Software (ArtSoft software)
    Last Post: 04-14-2008, 02:14 PM
