586,414 active members*
3,011 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > OIL COOLER FLOW ALARM 2031
Results 1 to 1 of 1
    The problem was in fuse +24V in operator panel.
    In photo you will see the panel. Screw 16 pcs from back side and in right bottom corner there is fuse in input board 2A.
    this fuse was broken and none key was active in operator panel.
    The message alarm "OIL COOLER FLOW ALARM 2031" was only the FIRST error in table of errors and we can see only one alarm at once.
    Attached Thumbnails Attached Thumbnails IMG_0607.jpg   IMG_2887-01.jpg   IMG_2889.jpg
  1. OIL COOLER FLOW ALARM 2031
    By =aike= in forum Kitamura
    Last Post: 03-10-2017, 06:07 PM
  2. Replies: 1
    Last Post: 09-08-2011, 04:08 AM
  3. Replies: 0
    Last Post: 09-07-2011, 10:45 PM
  4. Sp. cooling flow alarm D 171.0
    By dibakar in forum Fanuc
    Last Post: 12-31-2010, 03:52 AM
  5. 907 Alarm-C lube tank flow 1/LB15
    By JonLed in forum Okuma
    Last Post: 03-30-2009, 05:42 PM
