586,072 active members*
4,574 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > New here. Can use a little help.
    Mar 2017
    9
    Hi.
    My name is Ed and I'm just getting into the CNC aspect my Sherline Mill and Lathe. Just outfitted my long bed Sherline lathe with CNC Mounts and motors. Running the correct version of Mach3 and have a Soigeneris ESS (model SSENC-2), dowloaded the patch from Warp 9 for the ESS. Everything loaded fine. Mach3 opens up, see's the ESS, but I can't jog the motors. I've been searching for the correct Pins and Ports configuration, but this a little new to me. I know this is a rookie mistake, and for that I apologize. Can anyone point me in the right direction for these setting. Much appreciated.
    -Ed/emojo5
    Forgot to mention the controller. I have a DeepGrove1 CNC Controller box using a Gecko G540 board. Thanks again.
    Aug 2006
    671
    Re: New here. Can use a little help.
    I believe that Gecko has a mach3.XML file that will have all the correct ports and pins already assigned.
    Actually, it's right here:
    http://www.geckodrive.com/support/ap...-xml-file.html
    download that and stick it in your mach3 folder and you'll see the "540B" as an option in the profile load window. That should get you started in the correct direction.
    Mar 2017
    9
    Quote Originally Posted by CS900 View Post
    G540 XML File - Step Drives - Application Notes - Support | GeckoDrive
    Thanks so much for the help. This is all new to new and It going to take a bit to get up and running. Really appreciate the help.
    -Ed/emojo5
    Aug 2017
    34
    im having the same issues, you ever get it figured out?
