586,060 active members*
4,158 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Aspire override spindle speed for drag knife
Results 1 to 9 of 9
    Feb 2017
    8
    Hello,
    My cnc machine refuses to operate below a certain rpm, so using the drag knife at 0 rpm proved difficult. I am able to solve it manually by changing the code, putting // in front of where ever it says M3 (a manufacturers suggestion)
    but it would be much better if I had something set up in the software that already knew to tell the cnc to override the spindle speed alarm, since there a number of people who may end up using it and I want to simplify the process.
    Does anyone know of how to set up a change or who to talk to about getting that done for aspire?
    thanks
    Isaac
    Re: Aspire override spindle speed for drag knife
    Create a new post processor for drag knife code that doesn't use the M3.
    Feb 2017
    8
    Thank you Gerry, that answer leaves me with more questions (like what is a post processor and how does one create one?) but I am grateful that you have headed me in a direction and I will now research post processor(ing)! if there are any tips concerning this it would be much appreciated.
    'thanks
    Isaac
    You choose a post processor to match your machine when you save the g-code from within Aspire.
    In Aspire, under Help, is a post processor editing manual.
    Feb 2017
    8
    Thank you Gerry, I now know what a post processor is, and where to find them...progress! I am wading through the manual, and will see how it goes from there.
    Feb 2017
    8
    When i saved the edited pp file, it just saved as a text document, is that normal?
    Also when saving the toolpath I seem to only have the one post processor option, not a list to scroll through, so I need to figure out how to change that setting so I can see all of them in order to choose the one I edited, any suggestions?
    Feb 2017
    8
    I figured out the drop down menu thing
    Feb 2017
    8
    All working! thanks for steering me right Gerry.
    :cheers:
  1. Spindle Speed Alarm Override Needed For Drag Knife Operation. Syntec 6 MD cnc
    By IsaacBuilt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2017, 07:26 PM
  2. donek tools drag knife with aspire 4.0
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 04-20-2015, 01:45 AM
  3. Spindle Speed Override: How to Implement?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-17-2014, 08:38 PM
  4. drag knife
    By cocojack1966 in forum Other Machine Topics
    Last Post: 05-12-2014, 06:11 PM
