Can anyone help a newcomer to UCCNC? Is there a way to get text box input from a macro using C# or is this not possible? Thank you.
Hey petroz,
Maybe if you explained on what your trying to accomplish we can be of more help.
Dan
The easiest is to use the built-in functions, copy from the documentation:
Function: string TextQuestion(string Questiontext)
Description: This function shows a Question form waiting for a string as the answer. The text of the question shown on the Form is the parameter.
Example: string val = exec.TextQuestion("Stop code execution?");
Function: double Question(string Questiontext)
Description: This function shows a Question form waiting for a double value as the answer. The text of the question shown on the Form is the parameter.
Example: double val = exec.Question("What X position to move?");
but you can also make your own forms if you want.
the example is what I needed.
