586,076 active members*
3,740 visitors online*
Thread: Power supply
Results 1 to 11 of 11
    Apr 2004
    297
    Power supply
    Could someone have a peek at this please. I posted earier but not sure if it went through.Thanks.
    Dec 2003
    24221
    Re: Power supply
    Looks basically OK, although there should be an inclusion in it for E-stop shut off.
    Al.
    Albert E.
    Apr 2004
    297
    Re: Power supply
    Thanks Al now coming from a newbie to all this does the estop get wired inline on the white side. This is one of the components i did not look into. Thanks
    Dec 2003
    24221
    Re: Power supply
    In the power side same as the fuse conductor, it is not normal to switch the neutral or usually necessary to also switch the N..
    Al.
    Albert E.
    Apr 2004
    297
    Re: Power supply
    Thanks Al will do.
    Apr 2004
    297
    Re: Power supply
    Attachment 355448layout so far. Im thinking motor connectors directly above drivers. And pp north of drivers. Still need estop.
    Apr 2004
    297
    Re: Power supply
    Here is a pic with estop Attachment 355512
    Dec 2003
    24221
    Re: Power supply
    That would work but usually it is incorporated with one that also shuts the spindle off.
    Al.
    Albert E.
    Apr 2004
    297
    Re: Power supply
    I dont think ill control tbe spindle Al. Here is the estop switch, it has two sides the red and green do i connect straight through on the red or the green im a little co fused or second guessing myself.Attachment 355542
    Dec 2003
    24221
    Re: Power supply
    Normally use the Red side it is N.C. that is the one you use, Green is N.O.
    Al.
    Albert E.
    Apr 2004
    297
  1. Replies: 1
    Last Post: 01-12-2017, 07:12 AM
  2. ANILAM POWER GENERAL POWER SUPPLY FLU3-65-6 - eBay Auction
    By dickcummings in forum For Sale Only
    Last Post: 11-28-2016, 01:09 AM
  3. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  4. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
