586,075 active members*
4,094 visitors online*
    May 2013
    14
    Rapids Exceeding Configured Axis Velocities
    I've had my mill setup and working for about 4 years and right before a job my aging computer decided to call it quits. Luckily I was able to pull the Mach3 folder off the hard drive and move it to a different computer.
    So I get the new computer fired up and start jogging the machine around and notice the steppers sound a little different. Then I notice that the feedrate display when jogging or running a g0 is 66 ipm however my velocities in motor tuning are set at 60ipm. Can anyone explain what is going on?
    May 2011
    308
    Re: Rapids Exceeding Configured Axis Velocities
    Not enough beer maybe?
    May 2013
    14
    Okay the problem has been resolved, but I'm not sure what the issue was. I switched from a computer running vista (Hey its the only 32 bit system I had at the time, don't judge me) to a computer running Windows 7 32 bit. Same configuration and things are back to normal.
    Yes, I should have been drinking more beer and playing with less Vista!
    Jun 2014
    777
    It was most likely a corrupt xml setup file. Mach3's favourite trick. In most cases duplicate motor tuning settings conflicting. Makes for some very odd behaviour, if you copy a velocity setting and paste a duplicate only with a different setting you get one speed in one direction and another in the opposite, I found Mach 3 to be doing this itself. Every time you open motor tuning window you need to go through the xml in notepad and look for duplicate settings.
  1. question about router velocities
    By gaber2611 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-15-2017, 01:57 AM
  2. Does any one knows in what axis the automatic turret is configured on a lathe!
    By MarkGerard363 in forum Mach Software (ArtSoft software)
    Last Post: 06-07-2014, 05:34 PM
  3. Z axis stalling on rapids
    By fbmstar in forum Mach Mill
    Last Post: 10-27-2010, 02:47 PM
  4. motor acceleration and velocities
    By mike hide in forum Joes CNC Model 2006
    Last Post: 01-01-2008, 03:46 AM
  5. Alarm,24&34 on Y-axis -only on rapids
    By Robmatsuura in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2007, 04:14 AM
