586,033 active members*
3,515 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Visual Mill Cut sequence
    Feb 2005
    53
    Hi, I'm doing 2 1/2 profiling in visual mill. How do you tell the software to do the outside cut last? So you get all the internals completed and the final outside shape last?
    Do you have to do it manually?
    Prboz
    Apr 2004
    5737
    Re: Visual Mill Cut sequence
    You could run it as a separate engraving operation, after the rest of the machining is done.
    Andrew Werby
    Website
    Mar 2006
    We do nested type parts, with multiple parts laid out on a sheet. Our typical processing will in involve 3 basic ops. We run a drilling op first which does all drilling on all of the parts. More drilling ops can be added for drilling various hole sizes. Then the next op will be for internal profiling- for all cuts inside all of the parts. This would be for large holes or other shapes cut out from the part. At this point, the final op will be for outside profiling which cuts the parts from the sheet. In this op you can specify parameters for any tabs that hold each part to the stock, if you want to use them. Basically, you can arrange the ops sequence in the tree by drag/drop or cut/past to get the order that you want. Hope this helps. -Rich
  1. Visual Cam 1.0/visual mill 6.0 5 axis?
    By Swets in forum Visual Mill
    Last Post: 03-05-2017, 10:32 PM
  2. Visual Mill 6.0
    By ibrich in forum Visual Mill
    Last Post: 08-14-2014, 09:48 PM
  3. Visual Mill 6
    By Prboz in forum Visual Mill
    Last Post: 07-07-2014, 06:49 PM
  4. Bob CAD or Visual Mill
    By nandomax in forum Uncategorised CAM Discussion
    Last Post: 05-25-2007, 02:55 PM
  5. Need help with VISUAL MILL
    By replicapro in forum Visual Mill
    Last Post: 06-18-2006, 04:06 PM
