hello Im relatively new to this site, as I am trying to learn as much as I can about CNC routering and making signs as such. I have the above machine and use vectrics pro to design in but am not sure that I exporting my saved file in the right format to cut out. Ive tried using the Laguna mmg extension but it doesn't cut deep enough even though its set for 1/2 in plus my zero xyz seems off when it starts even though I calibrate for the material and the tool. Im pretty sure its in the saving of the file that is my problem. Does anyone have a suggestion as to which one I should pick. I don't have a manual so Im trying to figure it out for which is appropriate for this machine. Thanks for any guidance on this
